Anyone have the part number of the pinch roller for a JVC HR-S7900U?
Looking to replace mine, but the service manual PDF I have does not list part numbers for this stuff, only has electronics diagrams and such.
I ordered SMC Electronics #VCRPR05 (http://www.smcelectronics.com/vcrpr.htm) but turned out the size was wrong. Too tall and wide.
Additionally, if anyone has any tips or tricks (or video) of common replacement on these, would be great! Most videos I can find are for audio decks, not a lot of VCR repair documented out there.
Thanks!
Might get some help from these recent threads:
https://forum.videohelp.com/threads/400147-Pinch-roller-replacement-on-Daewoo-VHS
https://forum.videohelp.com/threads/395519-Worn-pinch-roller-on-a-Bauer-VCC-612
In addition, if you go to sites which specialize in rebuild, repair, and restoration, you will find links to sites which rebuild these rollers. You send them your part, and they add rubber to the old core and then turn it on a lathe to the exact dimension required. I asked a similar question about an idler wheel over in the vinylengine.com site and got several recommendations:
https://www.vinylengine.com/turntable_forum/viewtopic.php?p=1093823#p1093513 -
Just make sure you get the same diameter, Almost all VHS pinch rollers have the same design, A center plastic sleeve holds a hollow roller on a stainless steel shaft:
https://kpcomponents.co/products/vcr-pinch-roller-17mm-x-4mm-x-18mm-pr14
Mitsubishi Video Cassette Recorder HS-MD3000E-T - Service Manual needed
By MarkO1981 in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2023, 16:05 -
Pinch roller replacement on Daewoo VHS
By autoreverse in forum RestorationReplies: 16Last Post: 1st Feb 2022, 05:20 -
Tapechek Videopro - Manual/Service Manual
By geordie10 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2020, 05:23 -
Worn pinch roller on a Bauer VCC 612
By HansensUniverse in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 4th Jan 2020, 01:14 -
Looking for service manual for Panasonic AG-DS850 and AG-DS555.
By digicube in forum RestorationReplies: 0Last Post: 29th Sep 2018, 12:00
