Try NordVPN to access Netflix or other streaming services from any country and also surf safely!
  1. My DVD failed Nero data verification but passes CDCheck. Which one should I trust? DVD plays fine on DVD player.
    canada
    Do you have the original files/iso?If you do you can do a check to see if the files match,i stopped using nero years ago and wouldn't trust any results from it.
  3. Yes I have the original DVD folder made using AVSTODVD. I use CDCheck to compare the burnt DVD and the original DVD folder on my hard drive. So I guess CDCheck is more reliable.
