I used a converting guide. I followed all the instructions exactly. The fps was 23,976 so i picked the VideoCD (NSCFilme).mcf using TMPGenc. I went thru everything i needed to, got down to using VCDEasy to burn it to cd and as its checking the sequence, an error comes up, that says the CD Image is 838383(some number) which is > 348833 (some smaller number). Not sure waht's the problem, anyone got any ideas.
Is the resulting mpeg too big for the CD?
80min CD = 80min VCD
74min CD = 74min VCD -
Possibly, i was pretty sure it said there was enough disk space, ill check it out some more and see. If i convert to VCD from DivX, does it make the file a lot larger?
Staxrip error converting MKV/264 to DivX HD
By jwjr417 in forum Video ConversionReplies: 7Last Post: 18th Apr 2010, 09:00 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Converting Error
By RVPizzle in forum Video ConversionReplies: 12Last Post: 28th May 2008, 05:36 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48
