Results 1 to 12 of 12
  1. i have one video 1920x800 but put on pendrive then play on my TV 19" this video is adapted in height, so the video is distorted...
    i need to convert this video from mkv to mp4 or avi with xvid codec (my TV don't have h264 codec to play original mkv video).
    i have try ffmpeg with:
    -aspect:v:0 2.40 -filter:v:0 "scale=1280:534" -y -tag:v xvid
    but same result: when play this video on my TV video is adapted in height....
    is a way to forced output video resolution without losing the original video aspect (2.40)? or add black borders on top and bottom?
  2. Code:
    ffmpeg -i input.mkv -vf pad=1920:1080:0:140 -c:v mpeg4 -q 4 c:a copy output.mp4
    The "140" creates equal borders at the top and bottom, 140 = (1080-800)/2
  3. oh god, you are little genius!
    from 2 days learning and trying to find valid string to do this but without success...
    thank you very much for your support. your suggestion work fine!
  4. with same principle above i have try to resize final video, with add black bars on top and bottom. try this:
    ffmpeg -i input.mkv -f mp4 -ss 00:00:45.00 -to 00:40:00.00 -c:a:0 libmp3lame -q:a 2 -ar:a:0 44100 -ac:a:0 2 -c:v:0 libxvid -q:v 4 -s 1280x720 -vf pad=1280:720:0:93 -y "output.mp4"
    i have problem with pad value..... why??
  5. the -s is set to 1280x720, not 1280x534
    You can combine scale and pad into -vf
    ffmpeg -i input.mkv -f mp4 -ss 00:00:45.00 -to 00:40:00.00 -c:a:0 libmp3lame -q:a 2 -ar:a:0 44100 -ac:a:0 2 -c:v:0 libxvid -q:v 4 -vf scale=1280:534,pad=1280:720:0:93 -y "output.mp4
  6. ok tanxs.
    i have also tried HandBrake, but how to add this feature? (resize video with balcks bands)
    try to add string -vf scale=1280:534,pad=1280:720:0:93 on Advanced option on video tab but without result.... suggestion?
  7. I don't think Handbrake has any way of letting you add borders. The Extra Options field is for codec options, not filtering.
  8. You can add borders with Avidemux or Staxrip, never seen this on Handbrake
  9. i have try Staxrip but not easy and very big program... at this point i preferred ffmpeg! easy and fast. tanxs to jagabo string!
    and tanxs to poisondeathray to your resizing string: it work very fine!
  10. hi guys. new problem.
    i have new video 1728x720. my TV is 1920x1080
    i have calculate 1080-720=360/2=180
    on this video i don't want scale video, only add blacks bands. then i've try:
    ffmpeg -i input.ts -f mp4 -ss 00:00:39.00 -to 01:39:00.00 -acodec copy -c:v:0 mpeg4 -q:v 4 -vf pad=1728:720:0:180 -y output.mp4
    but not work. why?
    work fine with prev setting with scale:
    ffmpeg -i input.ts -f mp4 -ss 00:00:39.00 -to 01:39:00.00 -acodec copy -c:v:0 mpeg4 -q:v 4 -s 1280x720 -vf scale=1280:534,pad=1280:720:0:93 -y output.mp4
  11. Since your TV stretches everything to 16:9 you want to add borders to create a 16:9 frame size. Since your video is 1728 pixels wide the 16:9 height will be 1728 * 9 / 16 = 972. So you need to add 252 lines total, 126 top and bottom.
    ffmpeg -i input.ts -f mp4 -ss 00:00:39.00 -to 01:39:00.00 -acodec copy -c:v:0 mpeg4 -q:v 4 -vf pad=1728:972:0:126 -y bliss.mp4
    Your TV will then stretch the resulting 16:9 video to its 16x9 screen, keeping the correct aspect ratio.
    Or are you looking to pad all four edges with black bars?
  12. ok. received. now i try.
    and about second query, no, i want only maintain the correct ratio. no other.
    edit: try now and work fine! many tanxs (again)
