hi
i am not able to play .dat file (in VCD)on my laptop.The same vcd plays in another computer(desktop) using the same player(windows media player ver 7).The VCD contains 2 files AVSEQ01.dat and AVSEQ02.dat.The first one plays even on my machine but not the second one.THe first one is of only 2 MB where as the second 759MB.THe error given is"Cannot play back the file.The format is not supported".I am also not able to copy the second file to my hard disk.It gives the error"Cannot copy:Invalid MSDOS function"
Can u please help
Thanx in advance
Vivek
You have not appropriate codec.
You may try Elecard's mpeg decoder package
http://www.elecard.com/download/ -
You may want to let us know what OS you are playing and what software you are trying to use to play the DAT files...
Supposing you run Win9x or Win ME I would suggest you go to the Microsoft website and download the latest version of Windows Media Player (6.4, 7 or beyond depending on which OS you are using). All the newer versions play DAT files.
Cheers -
i burned a vcd and now trying to open the .dat file in mpegav folder.. w/ wmp and all its displaying is opening media... nothing happens.
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 21:27 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 10:43 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
