Depends somewhat to how your DVD is authored. Each episode may be a title with either all titles in one titleset or each title in its own titleset. For these cases the guide works.
Then there may be only one title with each episode being a chapter in the title. Then you'll have to join subtitles together and know the legth of each episode to determine the offset for each joined subtitle. -
I think you mean to write 'demux'. And you will have to extract the DVD files from the ISO to do the job. And, since the Method 2 as mentioned in the guide to which videobruger linked is the better method, you'll also have to demux the 'assets' (video, audio, chapter points). As he also mentioned, if all the episodes are in the same PGC (same title), your job becomes much harder as then you'll have to join the subs as well.
Adding subtitles in a blu-ray
By MovieCollector in forum SubtitleReplies: 4Last Post: 12th Jul 2024, 03:35 -
Adding subtitles
By kirkmc in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2020, 02:39 -
Adding subtitles, just that
By Morton54 in forum SubtitleReplies: 2Last Post: 21st Oct 2019, 01:30 -
Adding subtitles
By Marios Georgiou in forum SubtitleReplies: 1Last Post: 29th Apr 2017, 15:49 -
adding embedded subtitles ??
By kenny1999 in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2016, 03:42
