Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
  1. Hi guys,
    What are some easy tools do convert video files (h264 in mkv containers) to audio files? The audio format should be .mp3 or another format that is compatible with android phones. Thanks!
  2. Member Ennio's Avatar
    May 2005
    Netherlands
  3. If your files have aac audio, you should be remuxing them to .m4a (lossless operation) rather than converting.
    FFmpeg is a good tool for this (it can also handle re-encoding if needed).
