Hi. I was recently send download links for a DVD which included the .VOB files plus all of the small files. However, I think 1 of the small files is missing or corrupted and when I burn it to a disc it is making a Data DVD rather than a regular one.
I have the software IFOedit which I know can create the necessary small files for the DVD to work but would appreciate some help with how to do it.
There are 5 VOB files which make up the movie. I also have a "VIDEO_TS.VOB" file, which is the title menu, and a "VTS_01_0.VOB" file which is the chapters menu.
I know I will need to scrap the current small files (.BUP & .IFO) to create new ones from scratch but can anyone here help with how to do that using IFOedit (and ensure the "title menu" and "chapters menu" work).
I agree with aedipuss. You haven't really provided enough information to conclude the IFOs and BUPs are defective.
The VIDEO_TS.VOB and VTS_01_0.VOB should each have their own IFO and BUP. If one's missing you can duplicate it from the other.
I test DVDs by doubleclicking the VIDEO_TS.IFO using MPC-HC. What did you use to burn this DVD? Always use ImgBurn. -
Also, if only 1 of each IFO or BUP is defective, it's no problem to fix. "BUP" = "backup" (of IFO). so if IFO is defective, copy the BUP & rename it to IFO. If the reverse, it shouldn't affect playback, but you could copy & rename there too.
That's the whole point of the redundancy, so it is able to withstand corruption. IFO is placed at innermost section of the disc, BUP at outermost, so scratches are less likely to be common to both.
Scott -
Again, if an IFO is corrupt (or MISSING), you can re-create it by just copying the BUP and renaming its extension to IFO (all else should be identical).
Remember that you need 1 IFO for VIDEO_TS (the Vmgr or Root/FirstPlay) and then an IFO for every VTS_## (each titleset).
So as an example: if you had VTS_01.xx files and VTS_02.xx files, you would need 3 IFOs: VIDEO_TS.IFO, VTS_01.IFO, and VTS_02.IFO. And you also would need 3 BUPs: VIDEO_TS.BUP, VTS_01.BUP, and VTS_02.BUP.
ScottLast edited by Cornucopia; 8th Feb 2021 at 19:12.
I need some help with FFMPEG and IFOEDIT for DVD authoring
By Videogamer555 in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2019, 23:44
