I have a couple "sing-along" blu-rays that I want to rip and have them work like they do on the discs.
In one case (Mamma Mia), if you pick the last English subtitle is shows up with just the words of the songs and they're in a colored box with highlighting as each word is sung.
Is there a way to make that happen, or is that a disc-only thing?
I've been using MAKEMKV and HANDBRAKE to create MKVs for my Plex server.
Results 1 to 13 of 13
What type of subs are they? If they are srt then you won't get any of those fx's. To use with a mkv file and depending on your playback device you need .ass format. There was a program called PunkGraphicStream ASS to Blu-ray subtitle converter ie ASS to SUP for changing an ASS sub with all the fx's into the image format that blu-ray uses. So I guess you need the reverse. Convert SUP to ASS and recognise and maintain the fx's - I think that may be a tall order if not impossible. So you may have to recreate them in aegisub64 to create the ASS format subtitle to use or embed as a soft sub within a MKV file. Then it depends on your media player. Popcorn A-500 and the Zappiti 4K models do as standalones
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
from this youtube clip of Mamma Mia - https://www.youtube.com/watch?v=ooBBqaqB1F0
they used a program called iKaraoke TunePrompter - https://www.youtube.com/watch?v=0rVPnS8DkZk -
They seem to be embedded in the MKV file. The image below is what you see in VLAN when you pick Subtitle Track 6 that's in the raw MKV rip. It's also exactly what you see if you play the blu-ray and use the menu to select Play Sing-a-Long version. I also need these to work using Plex.
[Attachment 57238 - Click to enlarge] -
Post a Mediainfo report of the file. https://www.videohelp.com/software/MediaInfo
What about KODI does it support image formats? Maybe the OP could try KODI instead of Plex apart from getting a suitable standalone media player with a video jukebox function?
Well here's the answer from the Plex site
Supported Subtitle Formats
The following formats are fully supported either as embedded tracks or external subtitle files. Full support means they are compatible with all Plex Apps, including clients that require transcoded media.
SRT (.srt)
SMI (.smi)
SSA (or ASS) (.ssa or .ass)
WebVTT (.vtt)
Other formats such as VOBSUB, PGS, etc. may work on some Plex apps but not all.
So when the OP posts a MediaInfo report something all posters should do on their initial post to save a lot of time and questions and answers!!!SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I did take the RAW MKV (which is 25GB so just way too big) and dump it into Plex. It lists the subtitles (all of them) as PGS. The 6th one works exactly as expected with one huge problem: Plex becomes very unstable. I needed to reboot after using it once and couldn't FF or RW without Plex going into a dead-end of just forever showing me the spinning (working) icon.
I'm also brand new here and based my post on another similar post I found here through google. It had no such MediaInfo report so I was unaware of that. Now I know:
General
Unique ID : 139593230495450382795822733590598679916 (0x6904ADA2BDEAA16B6BE0CCCB94B67D6C)
Complete name : E:\Download\Rips\2008 1080p RAW.mkv
Format : Matroska
Format version : Version 2
File size : 24.8 GiB
Duration : 1 h 48 min
Overall bit rate : 32.6 Mb/s
Movie name : Mamma Mia!
Encoded date : UTC 2021-02-02 02:04:23
Writing application : MakeMKV v1.15.4 win(x64-release)
Writing library : libmakemkv v1.15.4 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Bit rate : 24.1 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.484
Stream size : 18.3 GiB (74%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 4 272 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.25 GiB (13%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Bit depth : 24 bits
Stream size : 1.15 GiB (5%)
Language : English
Default : No
Forced : No
Audio #3
ID in the original source medium : 4353 (0x1101)
Format : DTS
Codec ID : A_DTS
Bit rate : 768 kb/s
Bit depth : 24 bits
Stream size : 598 MiB (2%)
Language : Spanish
Default : No
Forced : No
Audio #4
ID in the original source medium : 4354 (0x1102)
Format : DTS
Codec ID : A_DTS
Bit rate : 768 kb/s
Bit depth : 24 bits
Language : French
Default : No
Forced : No
Audio #5
ID in the original source medium : 4355 (0x1103)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 149 MiB (1%)
Title : Stereo
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
ID in the original source medium : 4608 (0x1200)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 42 min
Bit rate : 47.7 kb/s
Count of elements : 3548
Stream size : 35.1 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
ID in the original source medium : 4609 (0x1201)
Format : PGS
Bit rate : 36.3 kb/s
Count of elements : 3031
Stream size : 26.6 MiB (0%)
Language : Spanish
Default : No
Forced : No
Text #3
ID in the original source medium : 4610 (0x1202)
Format : PGS
Bit rate : 41.7 kb/s
Count of elements : 3058
Stream size : 30.6 MiB (0%)
Language : French
Default : No
Forced : No
Text #4
ID in the original source medium : 4611 (0x1203)
Format : PGS
Bit rate : 14.7 kb/s
Count of elements : 1286
Stream size : 10.8 MiB (0%)
Language : Spanish
Default : No
Forced : No
Text #5
ID in the original source medium : 4612 (0x1204)
Format : PGS
Bit rate : 15.5 kb/s
Count of elements : 1314
Stream size : 11.4 MiB (0%)
Language : French
Default : No
Forced : No
Text #6
ID in the original source medium : 4613 (0x1205)
Format : PGS
Bit rate : 961 kb/s
Count of elements : 7148
Stream size : 704 MiB (3%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:04:37.902 : en:Chapter 02
00:14:51.098 : en:Chapter 03
00:25:44.084 : en:Chapter 04
00:30:39.379 : en:Chapter 05
00:35:26.082 : en:Chapter 06
00:40:25.047 : en:Chapter 07
00:44:36.382 : en:Chapter 08
00:47:49.658 : en:Chapter 09
00:51:19.117 : en:Chapter 10
00:56:27.634 : en:Chapter 11
01:04:03.297 : en:Chapter 12
01:08:05.372 : en:Chapter 13
01:14:43.520 : en:Chapter 14
01:20:18.688 : en:Chapter 15
01:29:58.559 : en:Chapter 16
01:32:18.491 : en:Chapter 17
01:34:13.606 : en:Chapter 18
01:39:12.613 : en:Chapter 19
01:43:40.088 : en:Chapter 20 -
So, one odd thing about this is that it matches what I saw in Plex with it claiming all six subtitles are PGS format. However, only the sixth one is graphical in appearance. The others are all just your standard white text with no additional features.
Appearance has nothing to do with it.
PGS and Vobsub formats are a series of images not unlike thousands of jpg files. They can appear as any sort of image. SRT on the other hand are standard text just the same as you type an email. ASS are also a text format with added tags that allows for a range of effects very dependent on the media player. So I guess it is a problem with Plex and as they say not all Plex apps are equal.
PS If you want to reduce the size of the file a tad you could remove all the unnecessary tracks like languages and subs. Use MKVToolNix load the file and untick everything then tick the tracks you do need then make a new MKV file sans excess stuffSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 07:17 -
Stuck on DVDFab "DVD Copy expired"
By davevid in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2017, 23:56 -
problem "burning in" subtitles on download video that has soft subtitles
By kasfig in forum SubtitleReplies: 2Last Post: 1st Feb 2017, 16:47 -
Watermark only one frame and "direct stream copy" the rest in mkv
By ranmafan in forum EditingReplies: 16Last Post: 18th Nov 2016, 10:04 -
how can i insert the special caracter " eighth note" in subtitle workshop
By Sergio15226 in forum SubtitleReplies: 12Last Post: 16th Nov 2016, 18:33
