Just met with weird inconsistent results using srestore (IMHO).
I have telecined NTSC stream, that I've already mentioned in one of my previous posts (Restoring telecined video).
Here the another piece from the same program: https://drive.google.com/file/d/1ZO0V29X0uxzG3bKvqoydhkIvmg2PD9EC/view?usp=sharing
There are clearly noticeable distortions in certain places.
I'm using the following Avisynth script:
FFmpegSource2("face2_10bit.mov")
#LSMASHVideoSource("face2_10bit.mov")
#LWLibavVideoSource("face2_10bit.mov")
ConvertToRGB24()
ConvertToYV12()
# Just trying to trat top and bottom parts separately (doesn't work)
#top = Crop(0,0,-0,240).TFM().TDecimate()
#bot = Crop(0,240,-0,240).QTGMC(preset="fast").SRestore(frate=23.976)
#stackVertical(top, bot)
Crop(0,4,-0,-2).QTGMC(preset="fast").SRestore(frate=23.976)
TurnLeft()
DeStripe(2,3,16)
DeStripe(2,2,16)
DeStripe(2,1,12)
TurnRight()
#KillerSpots()
Spotless()
CropResize(640,360, 14,0,-6,0, InDAR=0.8, OutDAR=1.0, Info=false)
FineDehalo()
So, the result of that script in approx 7 cases from 10 (very approximately) produces video, preserving existing distortions: https://drive.google.com/file/d/1hHVAFl2g4eD7bbj2RHoXR2agwCsdq_HD/view?usp=sharing
But (there is the mystery) in some random cases preview in AvsPmod and VirtualDub2 shows nice and clean non distorted frames.
Attempt to output that video (with non distorted preview) still gives video with distorted frames.
So, once I've managed to save just frame by frame non-distorted preview from AvsPmod :https://drive.google.com/file/d/1bFoYUhqWPNHmZEodeAvH-X1GMdGmhDvF/view?usp=sharing.
Have no clue what could be the case of such inconsistent result.
Such things happen on both 32bit and 64bit Avisynth versions.
Any suggestion greatly appreciated.
srestore requires linear access an you cannot preview by jumping around or you'll get different results
If you want to preview, you have to go back about 10-20 frames then seek frame by frame -
The problem is that this is a shot between two others:https://drive.google.com/file/d/1WaKfFmu-lUn7-xNeQsLokfbzDOVQCwnv/view?usp=sharing
Attempt to "go back about 10-20 frames" brings me to the previous shot, and gives "stable" distorted image as mentioned above.
The question is how to get sure distortion free result (see above), that sometime I "mysteriously" manage to get?Last edited by semel1; 6th Feb 2021 at 10:33.
The matches are consistent if you go back 20 frames. If they give distortion, that's consistent, they always give the same distortion if you seek linearly.
The inconsistent behaviour occurs when you seek non linearly (forward/back). So you can try or cutting up the clip with different start points - that's how you mysteriously get different results - different matches are used
srestore is not perfect, sometimes clip is not solvable.
You might have to do some manual rotowork, masking, compositing -
Finally managed to get "mystery" result in100% cases without involving "... manual rotowork, masking, compositing" ... etc. .
1st - performed all necessary filtering exclude srestore and output to intermediate file.
2nd - load another script with intermediate file as source and srestore only in VirtualDub2
3rd - play whole video from the beginning till the end and then go back to the beginning.
From that point you get perfect (non distorted) stream that could be saved.
P.S. Such approach works on the single scene only.
Ideal solution(IMHO) could be if we can detect scene changes and perform srestore solving for each scene ("nullifying" previous "solvers) , keeping solving results for each scene in some kind of "indexing" file/memory and after that perform final output using these solving results.
Just an idea - I don't know if it even possible.Last edited by semel1; 7th Feb 2021 at 14:29.
Maybe using something like:
with XX being current framerate (or similar) would work, so that there are always 20 frames cached before sRestore is used.Code:Preroll(video=XX,audio=0)
(http://avisynth.nl/index.php/Preroll)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
TDecimate vs. Srestore?
By Vitality in forum DVD RippingReplies: 11Last Post: 19th Jan 2019, 20:13 -
QTGMC and Srestore Bouncing
By lomaidala in forum EditingReplies: 13Last Post: 17th May 2018, 12:11 -
srestore and framerates?
By killerteengohan in forum RestorationReplies: 11Last Post: 30th Jan 2018, 19:13 -
How do I use SRESTORE
By DaneClark in forum EditingReplies: 2Last Post: 4th Oct 2016, 22:32 -
My second DVD conversion - use SRestore or not?
By pooksahib in forum Video ConversionReplies: 10Last Post: 16th Apr 2016, 09:28
