Hi, there.
I downloaded a folder with 2 folders within:
VIDEO_TS
AUDIO_TS
How can I extract or convert these files so I obtain the 5 or 6 videos they contain to see at VLC?
Thank you
But I want to extract the several videos to see them at the TV.
Is it possible? -
Yes, check the VIDEO_TS folder.
Every movie has a name like VTS_02_1.VOB, where the first number is the movie number and the second number the part number; so a full movie goes g.e. with final number from 1 to 4.
You can easily extract and merge the whole movie with clever FFmpeg-GUI. All you have to do is point to one of the movie parts when searching for the source video, e.g. VTS_03_02.VOB and the whole movie will be ripped, merged and then available for further processing.
(unprotected DVD's only) -
You could use MakeMKV and load the VIDEO_TS folder into it. Actually it will want the VIDEO_TS.IFO file inside the folder. It will then wrap each individual title within the DVD structure as a MKV file
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thank you for all the advices.
The clever FFmpeg-GUI didn't function may be I didn't find FFplay necessary for the program to function.
But with MakeMKV I hadn't any difficulty because it is very easy. It has only a little problem ( not important ):
The first VIDEO_TS has 10 videos and it supplies only one video and not 10 independent videos.
But it's OK, that is not very important. -
https://www.makemkv.com/forum/viewtopic.php?t=9969
avi playing and conversion issue
By NMeins in forum Video ConversionReplies: 6Last Post: 2nd Nov 2020, 15:21 -
Conversion DVD to AVI
By Jomapil in forum Video ConversionReplies: 4Last Post: 19th Apr 2020, 06:40 -
DVD to AVI Conversion
By Menyman in forum Video ConversionReplies: 5Last Post: 9th Jul 2018, 09:40 -
howto 1080i-mpeg4 to 576i-mpeg2 for dvd burning
By hydra3333 in forum Video ConversionReplies: 19Last Post: 25th Sep 2017, 09:44 -
Cut AVI Without conversion
By omidsolo in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2016, 14:45
