Me doing a simple re-encoding:
I start-up MeGui, go to Tools - AVS Script Creator - Add the video; click on Save;
Encoder settings x265 -> I choose Config at the right, new window comes up;
'X264 configuration dialog"
I go to the last tab, 'Misc' and add at the top where it reads "command line commands"
--vf "scale=in_range=mpegut_range=full" to have a x265 inputfile, with a different colorspace, be stretched to the colorspace for x264
Doesn't work.
I add the following, instead of the above:
--pix_fmt yuvj420p
Also, errors.
I don't think the parameters are wrong, I'm 90% sure I'm adding this in the wrong place.
Also, you almost never want to encode full range video. Few devices will play it properly.
I browsed through all of the x264 parameters, but none allows me to change the color space.
This is .... impossible when using Megui and sending the videostream to x264 encoder ? Or does it need another step ?
Is it worth updating x264 encoder?
By killerteengohan in forum RestorationReplies: 3Last Post: 1st Feb 2021, 10:01 -
Color Space in x264 Via FFMPEG in CLI
By koberulz in forum Newbie / General discussionsReplies: 15Last Post: 11th May 2020, 13:48 -
How do I use a new x264 encoder version in MeGUI ?
By VideoFanatic in forum Video ConversionReplies: 4Last Post: 17th Apr 2020, 07:39 -
audio support in x264 encoder
By vhelp in forum Video ConversionReplies: 8Last Post: 2nd Nov 2016, 03:11 -
x264 CLI so slow
By TeNSoR in forum Newbie / General discussionsReplies: 24Last Post: 18th Feb 2016, 14:11
