Is it true that if u use a VCD adapter on your playstation eventually your playstation laser will wear out and your psx stop working?
Think about it this way.....
If you use your playstation only to play game CDs, it will still die eventually. But if you use your playstation to play game CDs AND VCDs then you will make it die even sooner. It's simply more wear and tear. -
My PSX is going through MAJOR wear and tear. The center piece that holds the discs has literally just fallen apart in pieces. It can barely hold a disc!
It's all from the constant disc swapping that i've done 10,000 times. My laser is ok though. No problems with that.
Tom Green Sucks!
Encoding for Playstation 3
By nerfgun in forum ffmpegX general discussionReplies: 52Last Post: 15th Mar 2010, 17:57 -
UK Playstation 3 Question
By Anakin in forum DVD RippingReplies: 10Last Post: 30th Aug 2008, 03:43 -
Backup of Playstation 2 games
By Gerald Sr. in forum ComputerReplies: 5Last Post: 15th Jun 2008, 12:16 -
1080i on PlayStation 3 using ffmpegx
By cpeel2300 in forum ffmpegX general discussionReplies: 0Last Post: 19th Dec 2007, 04:09 -
Playstation 3
By Jake802 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Jun 2007, 22:57
