Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
Results 1 to 13 of 13
  1. Hi.
    So I have a bunch of 4:3 files, and some of them are fully stretched to 16:9 when I play them on both my blu-ray players (Sony, Samsung).
    I noticed that the ones that are displayed properly in 4:3 are the ones with the resolution of 716x480, 718x480 or 710x480. But all the 710x478 or 716x478 ones are stretched to 16:9.
    I can get them to display in 4:3 using jmkvpropedit, the problem is that I don't want total 4:3 since they're slightly cropped on the sides, so the display AR of 4:3 is still a little stretched. The files with 480 pixels in height play perfectly on my player, not stretched to 4:3 or 16:9.
    How can I make my other files to be displayed that same way?
    Here's an example of a file that gets stretched:
    General
    Unique ID : 120257900448391114162956227335729815703 (0x5A78D44352B92EECA7A6FD190639A097)
    Complete name : E:\103.mkv
    Format : Matroska
    Format version : Version 4
    File size : 287 MiB
    Duration : 21 min 55 s
    Overall bit rate : 1 832 kb/s
    Movie name : Jack of All Trades - S01E03 - The Floundering Father
    Encoded date : UTC 2021-02-03 18:42:07
    Writing application : HandBrake 1.2.2 2019022300
    Writing library : Lavf58.20.100
    ErrorDetectionType : Per level 1
    Video
    Format : AVC
    Format profile : Main@L3
    Format settings : CABAC / 1 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference fra : 1 frame
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate mode : Variable
    Maximum bit rate : 2 000 kb/s
    Width : 716 pixels
    Height : 478 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Original frame rate : 29.970 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : A_AAC-2
    Duration : 21 min 54 s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Delay relative to video : -9 ms
    Title : Stereo
    Language : English
    Default : Yes
    Forced : No
    Text
    Format : VobSub
    Codec ID : S_VOBSUB
    Codec ID/Info : Picture based subtitle format used on DVDs
    Duration : 21 min 21 s
    Language : English
    Default : No
    Forced : No
    Menu
    00:00:00.000 : :Chapter 1
    00:04:57.587 : :Chapter 2
    00:11:53.169 : :Chapter 3
    00:21:22.002 : :Chapter 4
    I have the same issue with several mp4 files like these:
    General
    Complete name : E:\Download\S02E02.m4v
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/iso2/avc1/mp41)
    File size : 543 MiB
    Duration : 44 min 12 s
    Overall bit rate : 1 717 kb/s
    Encoded date : UTC 2016-04-09 02:29:34
    Tagged date : UTC 2016-04-09 02:29:34
    Writing application : HandBrake 0.10.5 2016021100
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 16 Ref Frames
    Format settings, Reference fra : 16 frames
    Codec ID : avc1
    Bit rate : 1 551 kb/s
    Width : 712 pixels
    Height : 482 pixels
    Original display aspect ratio : 4:3
    Frame rate : 24.426 FPS
    Minimum frame rate : 17.120 FPS
    Maximum frame rate : 29.970 FPS
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.185
    Stream size : 490 MiB (90%)
    Writing library : x264 core 142 r2479 dd79a61
    Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Menus : 3
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Codec ID : mp4a-40-2
    Bit rate : 160 kb/s
    Stream size : 50.6 MiB (9%)
    Title : Stereo / Stereo
    Language : English
    Default : Yes
    Alternate group : 1
    Menus : 3
    Menu
    Codec ID : text
    Language : English
    Bit rate mode : CBR
    Menu For : 1,2
    00:00:00.000 : Chapter 1
    00:05:00.233 : Chapter 2
    00:21:42.101 : Chapter 3
    00:30:45.444 : Chapter 4
    Bit rate mode : Constant
    Thank you.
  2. For the video with wrong DAR (display aspect ratio) try to remux them with clever FFmpeg-GUI.
    Load your file, main, multiplex, video and audio track are arready selected, click target file, accept the proposed filname, set the desired container (mkv, mp4), on aspect ratio set value and set here 1.333 (for 4:3), click multiplex. Done.
    Check with your BR-Player, if the aspect ratio is correct now.
    (You can also try 1.4, this is a little wider).
  3. Thanks, won't they be (slightly) stretched to 4:3 though, like they were when I changed the DAR with jmkvpropedit?
  4. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    If you are familiar with ffmpeg you can just change the aspect easily without Re-encoding. FFMpeg also lends itself to using it in a batch format,.
    Video normally plays in 16/9 format
    Width : 1152 pixels
    Height : 648 pixels
    Display aspect ratio : 16:9
    "C:\Users\Bud\Desktop\ffmpeg" -i "C:\Users\Bud\Desktop\0_0_xInstagram.mp4" -aspect 4/3 -c copy -y "C:\Users\Bud\Desktop\Aspect_0_0_xInstagram.mp4"
    Now plays in 4/3 format
    Width : 1152 pixels
    Height : 648 pixels
  5. I know, but that code will change the display aspect ratio to full 4:3 right? my files are all slightly less wide than 4:3, with a resolution varying from 710x478 to 712x482. So a full 4:3 aspect ratio means they get slightly stretched on my blu-ray player
  6. Add borders such as to pad them all to the same frame size, and encode as 4:3.
  7. @Sharc: thanks, but the idea is to not re-encode the files. My files that are 710x480 play in their proper aspect ratio, I don't get why 710x478 get stretched to 16:9.
  8. Because the container has no DAR Info.
  9. But it does, I've posted the details earlier:
    Video
    Format : AVC
    Width : 716 pixels
    Height : 478 pixels
    Color space : YUV
    Bit depth : 8 bits
    Default : Yes
    Forced : No
  10. This is the videostream info
  11. Ok.
    I've just compared it to a video that does play in the correct aspect ratio, and the main difference I can see is the "Original display aspect ratio : 4:3" part. But it still plays properly, not stretched to 4:3.
    Duration : 21 min 52 s
    Width : 718 pixels
    Height : 480 pixels
    Frame rate mode : Constant
    I'll try clever FFmpeg-GUI.
  12. Member Budman1's Avatar
    Jul 2012
    How your videos is sometimes complicated with resolution, actual resolution(width/height), pixel*frames and previous resolution. First you have to determine if the videos have letterbox, pillar bars added permanently. If the have then these will always take less screen area no matter how you set the aspect t.
    If the video is without permanent bars, the just set the aspect to the actual. In your case 712x468 are actually older to 3/2 than 4/3.
    Realize that if your video says 712x468 or other then that's all you have. Any filling of a 16/9 screen will be done by the player or tv.
  13. FFmpeg-GUI won't work, I get an error message trying to import the files.
    But I did find the solution!! I remuxed one m4v file with MKVToolNix, didn't touch anything, left it as 712x482 pixels (displayed 635:482, that's what Media Player Classic shows), and it now plays perfectly on my my player, no stretching to 16:9 or 4:3.
    The line "Original display aspect ratio : 4:3" present in the previous file is now gone, I don't know if that has anything to do with it. I wish I knew exactly was caused the issue, but I'm happy there was no need to re-encode!
    Now I'd like to use a command line with ffmpeg to batch remux all those m4v files to an mkv container? Could anyone help me with that?
