Results 1 to 12 of 12
  1. apologizing for my bad English I want to ask to community one help: i have many 4k videos both in MKV and MP4 format I would like to know what software to use to make blurays WITH MENU..blu i accept any suggestion so both software free and paid software....
    Aug 2006
    BD Wizard from DVDLogic can author a basic UHD Blu-ray with a menu. See https://dvd-logic.com/bd_wizard
    Thread started by the developer: https://forum.videohelp.com/threads/399490-DVDLogic-BD-Wizard-v1-0-released%21
  3. dvdFab and power2go13 is what i use
    Aug 2006
    mikyitalia wants a menu for his UHD Blu-ray. In the past, DVDFab's UHD Blu-ray authoring software, UHD Creator, was only able to author UHD Blu-ray without menus. Did DVDFab finally add the ability to create menus to its UHD Creator authoring software?
    BD Wizard does menu creation, although I think it may only accept demultiplexed audio and video files that are already compliant with the UHD Blu-ray spec as input. If BD Wizard doesn't include burning, ImgBurn is a good free burner.
  5. Can't speak about the past but I can tell you that is what I use to create menus. Look on website and read through the features
    Aug 2006
    OK, I looked at the Guide section on the DVDFab UHD Creator page. No help there. There was one screenshot featuring the words "no menu". Maybe it can copy a menu if one had the files and folders from a ripped disc?
    In 2020 UHD Creator couldn't create menus. See https://forum.videohelp.com/threads/399337-4K-authoring-with-FULLY-CUSTOM-menus-Is-it-...le#post2599554
  7. I use it a lot you can create menus
Name:	dvd fab menu.png
    Aug 2006
    Your example is for Blu-ray Creator, not UHD Creator. They are different DVDFab products. The product page for Blu-ray Creator indicates that it can create menus. The product page for UHD Creator contains nothing about menu creation in its features list or the guide.
    [Edit]However, if mikyitalia wants to create a Blu-ray (HD resolution) with a menu from 4K sources and not a UHD Blu-ray (UHD resolution) then Blu-ray Creator would work for that.
  9. Man they have to many products for me. thanks
    Aug 2006
    TMPGEnc Authoring Works 6 should also be able to create Blu-rays (HD resolution) with a menu from 4K sources. However, TMPGEnc Authoring Works 6 can't author UHD Blu-ray.
    [Edit] mikyitalia did say he wanted a "Blu-ray". Technically that is the HD variety, and there are several options for consumer Blu-ray authoring. However, I assumed he meant a UHD Blu-ray since he has a UHD source and there is just the one that I know of that is capable of creating menus. BD Wizard does author both Blu-ray and UHD Blu-ray. I don't know if it can convert non-compliant files if it receives them as input. It may require compliant input like some of the DVD and Blu-ray authoring software that I have tried or looked at in the past.
  11. Originally Posted by usually_quiet View Post
    Exactly
  12. If your 4K video contains HDR, it needs to be converted to SDR first. Otherwise, its color will become lighter and look like gray.
