Hello,
I am new to this method of work. and its alittle confusing to me.. I do know some coding so its not that bad. but need help with some stuff.
when i try to open script in virtiualDUb2
Im getting the error :
Avisynth Open Failure:
AVIFileSource: Couldn't open file "PassOne.mov"
(D:\AVISynth Scripts\2, autolevels andHDR x64, avs, line 3) //here i am using VD2 x64 also file is quicktime .mov prores 422.
this might be becuase of codecs but i have no idea how to fix that or where to download codecs from specifically proress 422
also this command is AviSource("LOCATION")
AVISource is for AVI , not MOV
You can use LSMash for Prores
https://github.com/HolyWu/L-SMASH-Works/releases/tag/20200728
LSmashVideoSource("PATH\PassOne.mov")
AviSynth WILL NOT Open in VirtualDubMod
By user10495 in forum Video ConversionReplies: 11Last Post: 16th Aug 2020, 07:44 -
Avisynth/VirtualDub2 open failure Script error
By Pixl_talian in forum Newbie / General discussionsReplies: 29Last Post: 2nd Aug 2020, 17:10 -
avisynth open failure:FFVideoSource: Video codec not found using vafe
By NightBreaker in forum Video ConversionReplies: 1Last Post: 7th May 2018, 09:26 -
AvsPmod - Can't open in Avisynth 2.6
By VideoFanatic in forum Video ConversionReplies: 1Last Post: 21st Jan 2018, 07:27 -
Avisynth open failure:AVIS...couldn't locate a decompressor for fourcc HFYU
By CZbwoi in forum RestorationReplies: 18Last Post: 17th Apr 2016, 17:33
