I'm looking for option, that allows me to replace the current video frame by duplicate previous or next frame with "hot keys"(let's say CTRL+->/CTR+<-) using (preferably)VirtualDub2 + Avisynth .
Any suggestion would be greatly appreciated.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
If you're using avisynth, it's pretty easy to do in avspmod, you can write a macro and map hotkeys to whatever keys you want.
[Attachment 57093 - Click to enlarge]
vdub2's script editor is more rudimentary, I do not think it's possible there
I attached the 2 macros, you place them in the macro folder. They are just text files, renamed .txt extension to .py (it's python based)
ReplaceCurrentFrameWithPrevious.py
Code:frame = avsp.GetFrameNumber() avsp.InsertText('\nFreezeFrame(%i,%i,%i)' % (frame, frame, frame-1)) avsp.ShowVideoFrame(forceRefresh=True)
Code:frame = avsp.GetFrameNumber() avsp.InsertText('\nFreezeFrame(%i,%i,%i)' % (frame, frame, frame+1)) avsp.ShowVideoFrame(forceRefresh=True)
find and replace string with " double quotes "
By marcorocchini in forum Newbie / General discussionsReplies: 21Last Post: 27th Nov 2019, 14:15 -
Free(?) software to replace YouTube's "Enhancements"?
By clemenzina in forum EditingReplies: 0Last Post: 17th Jul 2018, 05:10 -
Use ffmpeg to replace frame with previous frame if frames are X % different
By dkrichards16 in forum ffmpegX general discussionReplies: 0Last Post: 29th Apr 2017, 16:27 -
Finding individual "bad" frames in video and save frame number, or repair
By johnmeyer in forum RestorationReplies: 6Last Post: 13th Dec 2016, 20:59 -
Premiere Pro CC 2015 - "Step Forward 1 Frame" doesn't jump to next frame
By xyron in forum EditingReplies: 1Last Post: 30th Nov 2016, 09:05
