Hi,
Doing digital transfers of old VHS tapes. A small section (about 2.5 inches) got mangled in my VCR. What will happen if I try to rewind the tape and play it? Or just looking for a fix (will I have to splice it?). Thanks so much I appreciate any help, I do not know a lot about VHS tapes.
Also, sorry if this question has been asked before.. I've been doing research but I always like to ask on forums
vhs is about 1.5 inches per second so your 2.5 inches is a little longer than second and a half. i wouldn't splice it as you're likely to make the problem longer and worse. just accept the dropouts.
Only splice it if it's clogs the heads or is in a spot where's there's nothing will be missed.
Covering a small section of a video
By devdev in forum EditingReplies: 2Last Post: 18th Dec 2020, 01:07 -
overlay some text with a black background/white text over one small section
By devdev in forum EditingReplies: 0Last Post: 16th Dec 2020, 12:27 -
Before you digitize that VHS tape, check the VHS VAULT first!
By babygdav in forum Latest Video NewsReplies: 20Last Post: 22nd Jun 2020, 16:33 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 07:14 -
standard VHS tape in S-VHS cassette
By smartel in forum Newbie / General discussionsReplies: 8Last Post: 27th Dec 2018, 21:28
