I have been using a version from 2013 for years now, and it has always worked fine for me. Is there any real benefit to updating it to a more modern 2020+ version? Has it been improved much or enough to be worth bothering to do?
I'm usually more of a "If it isn't broke, don't fix it" kind of person. Will the quality of my encoded video come out a noticeable amount better by updating just that x264 encoder?
Is that hard to do own tests instead of waiting for reply on some forum?
OP is encouraged to do his own test and if conclusive provide the result to the forum.
I doubt you'll see any improvement in quality, might be worth it for speed. Most changes since then are for improvements in speed, minor bug fixes, support for new instructions , and dropping older architectures.
How do I use a new x264 encoder version in MeGUI ?
By VideoFanatic in forum Video ConversionReplies: 4Last Post: 17th Apr 2020, 07:39 -
How to get current X264 Encoder accessible via Apple Compressor
By Christina in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2019, 22:58 -
x264 encoder presets and decoder compatibility
By aleaksunder in forum Video ConversionReplies: 5Last Post: 10th Feb 2019, 06:22 -
audio support in x264 encoder
By vhelp in forum Video ConversionReplies: 8Last Post: 2nd Nov 2016, 03:11 -
Concatenating 2 files with diffrent encoder setting (x264)
By ben45 in forum Video ConversionReplies: 25Last Post: 11th Oct 2016, 10:45
