Is it possible to re-encode a video with XmediaRecode and get an output video with a Frame rate mode of Variable?
Variable is not listed in the drop down box for Rate control mode: in XmediaRecode. I tried 2 pass ABR and it doesn’t produce a variable frame rate mode according to MediaInfo.
I’m trying to reduce the size of some 1 GB videos and I use to thing that reducing the bit rate was all that was needed. That will reduce the size but reducing it too low will also reduce the quality. All my 1 GB videos have a bit rate of 3000 kb/s and a frame rate mode of Constant. My smaller videos (same run time) have a frame rate mode of Variable. I have one video with a bit rate of 6800 kb/s and Variable frame rate mode and it is only 300 MB. All the videos are x264.
I don’t know what the pros and cons are between Constant and Variable other than file size. I was able to reduce a 1.3GB file down to 650 MB by selecting Constant Quality with a setting of 20.0 but the Frame rate mode in still Constant.
Perhaps XmediaRecode isn’t the best application to use for what I’m trying to do.
Rate Control modes and ABR have nothing to do with frame rate, they are bitrate settings. Generally, variable vs. constant frame rate has little effect on the file size. Bitrate is what effect file size. If you want a smaller file use a lower bitrate.
the only exception i know of being video comprised of a series of still pictures allowing framerate to drop to 0.
That's what I always thought. Instead of trying to find the best (quality vs size) bit rate I think I'll use the Constant Quality setting in Xmediarecode with a setting of 20 (default). It might not work for all videos and if it doesn't then I'll try something else.
Need variable frame rate ffmpeg
By Budman1 in forum Video ConversionReplies: 15Last Post: 9th Mar 2020, 06:10 -
Making a Variable Frame Rate video
By Mr. Anderssarian in forum Video ConversionReplies: 3Last Post: 1st Jan 2019, 18:17 -
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 06:01 -
Variable frame rate into constant frame rate without re-encoding
By DunnoNo in forum Newbie / General discussionsReplies: 8Last Post: 21st Dec 2017, 12:05 -
Variable Framerate to Constant Frame Rate
By jjcinema1 in forum Video ConversionReplies: 5Last Post: 6th Nov 2016, 21:29
