after ripping with smart ripper,converting with dvd2avi,then tmpgenc,my video is jerky in most scenes.can you help?i am using mpeg2 svcd,i tried different frame rates 23.9,29.9,30 fps,nothing changed.im using cbr,i also tried interlace 3:2 pulldown,inverse,when using these it spaced out the jerkiness a little bit.in other words ,rather then jerking every 2 or 3 seconds it would jerk every 5 or six.thanks
Did you convert the frame rate? i.e. is the source say 29.97 and output 25 (NTSC to PAL) or from file (23.97) to whatever?
If you did this can cause jerky playback. There are guides on the site adressing this problem but it you did NTSC to PAL (or visa versa) I would suggest don't bother, if your player etc handles it. -
i'm assuming svcd since you failed to offer even this most basic of info. did you check the field order before encoding? if you got it wrong demux the video & feed it thru pulldown using the -nopulldown -tff [odd, even] switches to swap out the field order
Jerky Video.
By wasimismail in forum Video ConversionReplies: 27Last Post: 15th Dec 2009, 12:35 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 12:59 -
video still jerky
By milway in forum Video ConversionReplies: 15Last Post: 3rd May 2008, 17:01 -
Video is jerky
By arnie22112000 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 01:49 -
Tmpgenc producing Jerky video?
By love2learn in forum Video ConversionReplies: 7Last Post: 11th Nov 2007, 09:37
