Gday,
I'm trying to create a HEVC file, using Handbrake, that will play on my LG TV. I have tried many combinations of settings of the "Video" tab but have had no luck eg Codec, Encoder tune/profile/level; my TV keeps saying "unsupported format", as does my WDTV Live. But, I have created an HEVC video with Movie Edit Pro that does play on the TV (using Main, Level 4); annoyingly, that file won't play properly on an ipad.
The TV specs indicate that it should play HEVC videos.
If somebody has successfully created a HEVC file for their LG TV, I would be grateful if you could share the settings you used.
Thanks, Al
Here you go:
General
Complete name : H:\Misc Video\HEVC Handbrake\HB HEVC 1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/iso2/mp41)
File size : 1.24 MiB
Duration : 16 s 480 ms
Overall bit rate : 632 kb/s
Encoded date : UTC 2021-01-30 06:11:51
Tagged date : UTC 2021-01-30 06:11:51
Writing application : HandBrake 1.3.3 2020061300
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 518 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.010
Stream size : 1.02 MiB (82%)
Writing library : x265 3.2.1+1-b5c86a64bbbe:[Windows][GCC 9.2.0][64 bit] 8bit+10bit+12bit
Encoding settings : cpuid=1049071 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=40 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=15 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=2 / selective-sao=4 / no-early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=500 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 16 s 406 ms
Bit rate mode : Constant
Bit rate : 107 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 214 KiB (17%)
Title : Stereo
Language : English
Default : Yes
Alternate group : 1
Tagged date : UTC 2021-01-30 06:11:51 -
Thanks Dave and ProWo, I worked out what the issue is: Serviio! It mustn't be talking to the TV properly, because when I put the files into the Windows Video folder, they play correctly through the Windows Media server.
Sorry for the false alarm!
On the subject, Serviio isn't going very well these days; apart from the issue of not correctly playing files over the network, it never picks up new of changed files unless I open the console.
Any suggestions for another media server for Windows?Last edited by Alwyn; 30th Jan 2021 at 05:32.
Nvidia HEVC (2 Pass on Handbrake)
By Daringbaaz in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2020, 12:20 -
FFMPEG HEVC/H.265 settings help
By kevindd992002 in forum Video ConversionReplies: 4Last Post: 31st Dec 2019, 22:40 -
HEVC Encoder and settings
By Cyano in forum Video ConversionReplies: 3Last Post: 8th Feb 2018, 07:55 -
HEVC x265 potplayer settings
By Annonboy777 in forum Software PlayingReplies: 0Last Post: 13th Jan 2017, 07:21 -
Avidemux Nvidia H264 / HEVC settings
By frenksisco in forum Video ConversionReplies: 2Last Post: 19th Dec 2016, 06:51
