I currently have a Matrox MX02 that records in i-frame MPEG 2 and I was wondering if a capture card like a AJA KONA LHI that can capture in DV50 which format would be quicker, and easier to edit with on a modern system?
I consider both systems to be "legacy" intermediate codec level. In this sense: while intra-frame, they are both lossy codecs using older technology.
Neither would likely be hard to work with on a modern edit system, but neither would be the best quality. Mpeg2 may or may not have an advantage, as it is slightly newer technology (codec-wise) and thus more efficient. Plus DV50 is a CBR static bitrate (50Mbps), while MPEG2 could conceiveably have multiple tiers of bitrates for that codec implementation, with even the possibility of variable bitrate (obviously, 1-pass).
Personally, since Kona appears to give you the option, if it were me, I'd use that hardware and use ProRes as the codec, since it will look much more like lossless. It is also a newer, more efficient techology though it is proprietary (Apple). I'd use a very high bitrate for quality stuff and a medium bitrate for most simple stuff and low bitrate for proxy complex edit stuff. But you will have higher hardware burden (both storage & throughput, and even a little bit processing) using Prores compared to the other 2. But I'd go for the quality.
Scott -
Btw, for those who may be thinking it, yes full lossless would be better quality and doable on many modern systems. But they don't appear to be directly supported in hardware with either of these 2 offerings, so I skipped that possibility.
Scott -
Both the Matrox and AJA can record uncompressed, but the files are massive.
It's not just basic recording, but the intermediate rendering, using those hardware to accellerate encoding & decoding, which can make the editing easier, more fluid/faster, and yet still fairly high quality. That's much of the reason those were chosen as default.
It's all about compromises (assuming all I-frame):
1. Low bitrate = low pipeline & storage burden, and low quality+low complexity or higher quality+higher complexity
2. Med bitrate = med p&s burden, med quality & med complexity
3. High bitrate = high p&s burden, high quality but low complexity
Aero Glass on Windows 7 on modern AMD processor.
By Moline in forum ComputerReplies: 4Last Post: 24th Aug 2020, 04:16 -
Importing a translated script into ssa file in Subtitle Edit-keeping format
By JEJP in forum SubtitleReplies: 2Last Post: 5th Aug 2020, 08:19 -
How to get started with avidemux, edit and convert any video format
By Baldrick in forum User guidesReplies: 114Last Post: 16th Nov 2017, 16:29 -
Which is easier to edit? DVD MPEG-2 or H.264 MP4?
By digicube in forum Video ConversionReplies: 9Last Post: 5th Jun 2017, 16:12 -
Best Way to Edit AMR File Format on Windows?
By pone44 in forum AudioReplies: 2Last Post: 21st Jan 2017, 09:20
