I have a Sony Andriod TV that has a defective USB system. Can I connect a USB A to HDMI, using a coupler to make it female, without damage to the HDMI ports?
The connectors I found only have male connection.
No. HDMI and USB are completely different systems. If you want to view video files on your TV (with dead USB ports) you need a media player like the latest Chromecast with Google TV. Plug it into an HDMI port on your TV and start playing videos.
I can't think of any USB devices that one would normally connect to a USB port on a TV that would work when connected to HDMI. What USB device are you trying to attach to HDMI on your TV?
HDMI connections on a TV only accept uncompressed video and digital audio. Although some HDMI cables have the ability to provide an Ethernet connection, I have not heard of that feature being used yet for any TV. Normal HDMI connections supply a small amount of current to connected devices but since all versions of USB supply considerably more current, HDMI cannot substitute for USB power.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
There is ONE exception: USB-C (v3.1, 3.2...) --> HDMI adapter. USB-C has a "Alternate HDMI" mode protocol that allows hdmi to piggyback on the usb serial signal until it gets to a converter/adapter.
Scott -
Are there any HDMI to USB cables for using a camcorder- as a webcam?
By videofan70 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 2nd Mar 2020, 12:37 -
HDMI to USB for Pinnacle 22 Ultimate
By DLCP in forum Capturing and VCRReplies: 4Last Post: 3rd Dec 2019, 19:34 -
Hdmi Or Usb Video Caputre for Pc - Recomendations
By dreico33 in forum Capturing and VCRReplies: 26Last Post: 13th May 2019, 18:28 -
HDMI over USB-c
By therock003 in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2018, 15:18 -
Magewell USB to HDMI Capture Device HELP
By bdizzle009 in forum Capturing and VCRReplies: 2Last Post: 6th Feb 2017, 06:21
