Results 1 to 13 of 13
    Jan 2021
    United Ststes
    I own a JVC Super VHS ET HR-S4800U which I bought off of eBay a number of years ago for the purpose of transferring video tapes to DVDs. I have it connected to my desktop computer via an S-video cable and two audio cables through a Hauppauge 1600 TV tuner card. When I first got it, everything functioned properly, including picture and sound. Now, however, when I insert a video tape, everything functions correctly - EXCEPT that I get no picture or sound ,
    Any suggestions as to how to correct that would be greatly appreciated. And for what it's worth, I also have a copy of the service manual for it.
    Thanks in advance.
    Oct 2005
    666th portal
    trash bin. toss it.
  3. I have a hop hog and from memory (it is unused these days) it needed a ton of hop hog software installed before it would even begin to say hello
    Oct 2005
    666th portal
    lucky you. hope it doesn't eat you next time you attempt to use it.
    Oct 2018
    Town Spa Pizza, United States
    What software?
    What connections?
    What OS?
    Jan 2021
    United Ststes
    Originally Posted by Barrythecrab View Post
    What software?
    What connections?
    What OS?
    The software is TV-Viewer (found here): https://sourceforge.net/projects/tv-viewer/
    I said what the connections are in my original post.
    My operating system is Slackware 14.2 (64-bit).
    May 2005
    Australia-PAL Land
    Does it produce a picture when plugged into a TV? If so, Windows 10 might be messing with you/your card. If not, VCR deddybones?
    Jan 2021
    United Ststes
    I haven't tried that yet, but as I said in post #6, my operating system is Slackware 14.2 (Linux-based).
    May 2005
    Australia-PAL Land
    Yes, sorry about that. I had it in my mind that Slackware was a Windows proggie.
  10. Video Restorer lordsmurf's Avatar
    Not the best for transfers. You must have an ES10/15 between this VCR and that capture card.
    You need to hook the VCR up directly to a TV, ignore the capture card for now.
    trash bin. toss it.
    NEVER!
    DO NOT DO THIS!
    The JVC HR-S4800 has value, even as parts.
  11. Capturing Memories dellsam34's Avatar
    Jan 2016
    I believe it's capture software/OS related problem, but since you're using this "Slackwire OS" thing your chances of getting help will be very slim, I personally never heard of it. How did you manage to find drivers for the card?
    No don't be stupid, don't throw away the VCR.
    Jan 2021
    United Ststes
    For what it's worth to you, I have no intention whatsoever of throwing it away.
    And as far as the drivers are concerned, the software that I use requires that "ivtv-utils" needed to be installed, which i found at Slackbuilds.org, and I mentioned in post #6 what software I have used in order to view video tapes and/or watch TV programs.
    Jan 2021
    United Ststes
    You're right - it WAS the tuner card, I connected my VCR directly to a TV and got both picture and sound. So apparently at some point, my tuner card must have "died" on me. As a result, I am in the process of replacing my tuner card.
