I am looking to resize and upscale some of my videos with FFMPEG as the other alternative but what is the FFMPEG alternative to "Nearest Neighbor", "Lanzcos3" and "PointResizing"? I also want to make my videos the "HD" with a 4:3 ratio. I mostly use Virtualdub2 for resizes but some people suggest I use FFMPEG for resizes. What is the equivalent of that stuff on FFMPEG?
Results 1 to 16 of 16
https://ffmpeg.org/ffmpeg-scaler.html
-vf scale=1920x1080:flags=lanczos
or -vf scale=504:376 -sws_flags bilinear
default is a sharp bicubic. -
Of course you also substitute the '1920*1080', which is 16:9 with 1440*1080. But I guess you already knew that.
I mostly used Virtualdub2 for my upscales. I also had to look up the sizes as well.
SWScaler options for ffmpeg:
Note that those are simple resizers, not neural network, AI, upscalers. ffmpeg also supports a few nn upscalers like nnedi and srcnn.Code:SWScaler AVOptions: -sws_flags <flags> E..V...... scaler flags (default bicubic) fast_bilinear E..V...... fast bilinear bilinear E..V...... bilinear bicubic E..V...... bicubic experimental E..V...... experimental neighbor E..V...... nearest neighbor area E..V...... averaging area bicublin E..V...... luma bicubic, chroma bilinear gauss E..V...... Gaussian sinc E..V...... sinc lanczos E..V...... Lanczos spline E..V...... natural bicubic spline print_info E..V...... print info accurate_rnd E..V...... accurate rounding full_chroma_int E..V...... full chroma interpolation full_chroma_inp E..V...... full chroma input bitexact E..V...... error_diffusion E..V...... error diffusion ditherLast edited by jagabo; 27th Jan 2021 at 08:20.
Hmm... this got me thinking now. The nearest neighbour/point algorithm in particular. Mostly, when resizing, I have been using flags=none and understood that would be the same as nearest/point. I've been using that for years, many years, I remember specifically reading somewhere about how to eliminate the default bicubic filter, not really because of how it looks but simply because nearest is much faster . And I have a distinct memory that the flag for that was simply "none".
Now that I read the docs now... there is no such flag listed, however "neighbor" is. Anyone happen to know whether they're the same thing and "none" is just deprecated or something? It's weird, because there's no errors or anything to indicate otherwise, so I've assumed it works and did what I thought it did... but it actually isn't documented! At least not anymore. -
I tried it as far as to see that for example "-vf "scale=1440x1080:flags=noune" gives an error message, like you'd definitely expect... it's a syntax error, or not really, some kind of lookup table, but it's an error. It's a complete mystery what the "none" means. It's nowhere to be seen in the docs. I don't have the know-how or other software to do a comparison (easily), I suspect it goes to defaults or something. But it's really weird, why does it accept an argument that's not documented? I can't even find the site or sites where the "none" was, this was something like 4 years ago. And do note that this is "flags=none", not "sws_flags". Live and learn, I guess.
BTW same thing with x265 and limit-sao. I have no idea if it's enabled or disabled, it's accepted as a parameter but it's not visible anywhere if it's active during an encode. (and as far as that goes... I have SUB-zero knowledge how to figure something like THAT out after the fact...)Last edited by non-vol; 27th Jan 2021 at 09:25.
Oh, that's interesting. Thanks for the tip. I still think it's a little odd that those things aren't shown during the encode... since a whole lot of stuff is. I also thought that info might be present in some separate log file... which might be in some very random directory (Windows build...) . Really off-topic already but actually getting the live console log to also be saved onto a file would be nice. I am sure there possibly might be a switch to do that or maybe that just happens... surely it would be in /var/*, /etc/*, ...
The codecs' internal settings are invisible to ffmpeg. For example, if you just specify "-c:v libx264 -preset slow" ffmpeg doesn't know how that effects all the internal x264 settings. Any other settings you specify -- well, you just put them on the command line so you know what you set. And ffmpeg doesn't know if the codec paid any attention to them.
Is there an equivalent to SmartCutter Ps/Ts for JOINING video?
By 90sTV in forum MacReplies: 7Last Post: 23rd Dec 2019, 19:43 -
Upscaling
By DiggyDre in forum EditingReplies: 2Last Post: 16th Feb 2019, 21:42 -
Avisynth equivalent plugins for vapoursynth
By zanzar in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2019, 12:58 -
Equivalent of filter "Limiter" from Audacity in ffmpeg
By lenberg in forum AudioReplies: 1Last Post: 10th Oct 2018, 10:00 -
x265 CRF value equivalent to x264
By Wakaku in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2018, 15:33
