Hi guys
I have a win xp machine, fresh install only used for 1 program
Pinnacle 8 with the Pinnacle capturecard Av/dv with bluebox breakout.
After fiddeling around I got it to work perfectly, 2 hour capture 0 frames dropped.
In the capturepreview screen audio is in sync with video
BUT!
Final result: a consistent out of sync audio from the start of video till the end, for a bout 0.3-05 seconds.
Noticable. So how to fix this or has someone suggestions?
Problems - Solutions I thought of myself:
- Internal audiocar on motherboard, replace with better one?
- Install Codec Pack (is now on install codecs only)
- HDD Writespeed not fast enough? (came with pc)
Not helpfull comments:
- buy an ATI AIW! (there are hard to come by here in NL)
- buy an external TBC! (no money for it)
- Use Virtualdub! (Card will not be recognized by other then pinnacle)
Helpfull comments:
- Yeah buddy, Pinnacle sucks! I had the same problem you should install this. or this, or try that!
- Just fix it in post! use Avisynth to sync the audio using this script .... (i've been trying to find one but that's a whole forrest i can't seem to get trough yet)
Specs
PC:
Windows XP Pro 2002 SP 2
Pentium 4 cpu 3ghz 1.75GB ram
NVideo GeForce 4MX 460
Pinnacle AV/DV deluxe capturecard with breakout box (bluebox)
pinnacle callisto rev 7.0
JVC HR-S8600 with TBC/NR
Thanks so much for any help! I've been installing, re-installing and figuring out what could be the problem for hours and days!
I hope some-one can help me out so I can get some sleep
You should be getting audio from the capture device, not the motherboard or other audio device.
You can try my clever FFmpeg-GUI for the final encoding of both video and audio tracks. Then you can mux them, specifying the necessary audio delay.
The resulting video should be in synch. -
Hey Former me! Guess what, after digging for hours, there are people that are having the same problems!
Here is a link from 2003! https://forum.videohelp.com/threads/100379-Out-of-sync-audio-problem-with-analog-capture-Pinnacle
Download ScenalyzerLive from the site, add license and see if that helps!
Thanks man, Trying it out now... will post results!
Converting to constant framerate with Handbrake - Audio out of sync
By m1ke in forum Video ConversionReplies: 3Last Post: 1st Nov 2020, 18:27 -
Audio Sync Issues with New (to ME) PC and Card
By RABinMS in forum DVB / IPTVReplies: 0Last Post: 29th Jun 2020, 08:53 -
Distorted Audio Output From Capture Card
By Xray74 in forum AudioReplies: 1Last Post: 29th May 2020, 04:58 -
WinDV capture : out of sync Audio?
By Topsy in forum RestorationReplies: 22Last Post: 2nd Nov 2016, 06:39 -
HD PVR 2 Capture card has audio issues. Any solutions?
By super6646 in forum Capturing and VCRReplies: 0Last Post: 17th Aug 2016, 18:40
