Results 1 to 12 of 12
  1. Hello. I have an 403 error on the MPD link of this stream:
    https://rakuten.tv/it/movies/un-gran-giorno-per-morire
    So I cant download it........could be someone can try and tell me
    how can I bypass 403error? thank you
    register with fake email e select a pass then login
  2. try adding --add-header "Range: bytes=0-690"
    youtube-dl --add-header "Range: bytes=0-690" "link.mpd"
    discord=notaghost9997
  3. Originally Posted by notaghost View Post
    with this sintax start to download but files are only 2mb
  4. change range
    https://imgur.com/XHn1dzH
    https://imgur.com/48WDPFF
    General
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41/iso5/iso6)
    File size                                : 1.15 GiB
    Duration                                 : 1 h 41 min
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 631 kb/s
    Video
    Format profile                           : Main@L3
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 1 500 kb/s
    Width                                    : 720 pixels
    Height                                   : 404 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 FPS
    Bits/(Pixel*Frame)                       : 0.215
    Stream size                              : 1.05 GiB (91%)
    Writing library                          : x264 core 148 r2708 86b7198
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=48 / keyint_min=24 / scenecut=0 / intra_refresh=0 / rc_lookahead=30 / rc=cbr / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=1500 / vbv_bufsize=4500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Bit rate mode                            : Variable
    Bit rate                                 : 128 kb/s
    Maximum bit rate                         : 1 500 kb/s
    Channel layout                           : L R
    Sampling rate                            : 44.1 kHz
    Frame rate                               : 43.066 FPS (1024 SPF)
    Stream size                              : 92.7 MiB (8%)
    Language                                 : Italian
    Default                                  : Yes
    Alternate group                          : 1
  5. downloaded the video and decrypted with bento, the video can be seen jerky and the audio is late...
    with ffmpeg worst.
    player tested: VLC, gomplayer, potplayer
    other: widevine decryptor ... we have for firefox?
  6. Doesn't work with Firefox Browser.
  7. can anyone download this video (decrypted)?
  8. extension works on Firefox Browser.
    https://forum.videohelp.com/images/imgfiles/KU7XKK6
  9. OK. Probably the code has been modified. It doesn't work for me.
    Upd.
    Understood. Working.
  10. Originally Posted by LZAA View Post
    extension is old. 30 Oct 2020. no modify
    but notaghost how to add to firefox? drag&drop folder not work.
  11. nice. tanxs LZZA for your work.
