Hi,
I have identical two numbers of sandisk pendrive of 64 gb storage. The two contain different filles altogether.
When i placed one pendrive, it reads the file and play the video correctly.
When i opt for the second pendrive, I get the alert, there is no device connected message.
I thought, that there would be some problem.
I just tried to read with the pc, and it works fine.
But on the usb port , this alert I mentioned.
Why this
i opted error checking quick and it does not show any errors and scan good.
Other pendrives are reading thro nicely.
please give me solution and also the probable cause for this
Results 1 to 18 of 18
Have you tried the other USB ports on your computer?
Extraordinary claims require extraordinary evidence -Carl Sagan -
Hi, the problem is in the usb ports of the Samsung TV. I have mentioned this in my opening thread. I have tried the available two ports of usb in the tv provided for that purpose
Your title was truncated as it's too long, so it didn't say what it was connected to.
What format is the USB drive, is should be FAT32 for the TV to read, but maybe it has been formatted as NTFS. -
Hi, darkknight,
the format is exfat, the other 64 gb is recognized and play fine.
In computer, it plays fine.
what would be the cause -
does the USB drive that plays the video correctly play in both USB ports ??
are you plugging both USB drives in both ports on your TV ??
it may be possible that only one USB port on the TV can only be used one at a time.
or the second USB port is only for factory service / diagnostic usage only. -
Obviously one of the TV's USB ports is not what you think it is.
There are two usb ports. And I use the correct port from where I am usually viewing. There is no device connected with the other usb port.
what would have been the cause.
Should I format and recopy the whole thing -
Sometimes the usb device gathers too much lint in the connector causing the device not to be read,if this is the case then you need to clean the usb connector with a toothpick or similar tool.
there are lots of fake counterfeit usb sticks out there. throw the one that doesn't work away and buy a good one from a reputable source.
Hi, it is original san disk. The other is working, and so there is no problem in the usb ports. Strange behaviour
As a way, i copied the files in a folders. Still no luck.
Other pendrives are working, chkdsk /r gives no bad sectors -
Hi, Jagabo, I said the other pendirve is working fine. So the exfat format, default is already on the pendrive.
Yeasterday i used chkdsk /r and it did not find any bad sectors.
When the same type of usb is working, why this is not working is the query.
The only alternative is to format and recopying the entire thing.
the problem is, if i copy again, the same file which is causing the problem would also get copied and the issue is back to square one -
lol. doesn't mean the seller of your drives sent you 2 of the same drives. throw the non working one away and buy a real one from a known good seller.
Hi, the latest
I found that one of the mp4 file extension has been changed to exe. Probably this may be the reason as exe file could not be opened in the usb tv port.
let me try some more things -
Hi, I just formatted the pendrive and then
formatted them with the ntfs format. The problem solved. Thanks for everyone
Shogon 7 from Atomos problem with more than two cameras connected
By pwn in forum Newbie / General discussionsReplies: 2Last Post: 23rd Oct 2020, 09:21 -
Help please!! How to power my external HDD connected to TV
By thegeeman in forum Newbie / General discussionsReplies: 27Last Post: 7th Jul 2020, 13:12 -
Syncing Video from Chrome/Firefox to HDMI-connected PC
By vid00d in forum ComputerReplies: 0Last Post: 1st Jul 2020, 20:16 -
VHS Player goes to no signal ONLY when connected to RCA to HDMI adapter
By spyjoshx in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2020, 17:51 -
Cannot change the sound volume when I connected ipad with an AAXA M6 projec
By pixelPIC in forum Portable VideoReplies: 0Last Post: 31st Aug 2017, 17:46
