I have finally gotten around to testing Ice Lake's hardware deinterlacer and here are the results. I encourage someone to post a test with qtgmc or whatever all the kids are using nowadays.
The test source can be found here:
https://forum.videohelp.com/threads/400431-In-need-of-a-a-decent-size-interlaced-sample
The test was done on Manjaro running on a HP laptop that uses a i5-1035G1 and these tests were done via Avidemux.
I tested all available vaapi deinterlacing modes, in both regular frame rate and double frame rate, and I tested with both x265+medium+crf 20; for vaapi I used Intel's hevc but Avidemux does not allow setting quality setting, just a max of 4 b-frames, a max of 250 gop and either bit rate based or "crf", which I used set at 20.
Thoughts are welcome.
Results 1 to 1 of 1
Fresh x264 10-bit vs Ice Lake hevc qsv 10-bit
By sophisticles in forum Video ConversionReplies: 5Last Post: 7th Jan 2021, 17:06 -
More Ice Lake Quick Sync test samples
By sophisticles in forum Video ConversionReplies: 13Last Post: 11th Nov 2020, 10:08 -
Ice Lake QSV Review/Test!!!
By sophisticles in forum Video ConversionReplies: 19Last Post: 1st Oct 2020, 10:14 -
Kaby Lake VP9 hardware encoder tested!!!
By sophisticles in forum Video ConversionReplies: 1Last Post: 8th Apr 2018, 13:14 -
Spectre and Melton Preformance Issues - Ice Lake vs Coffe lake
By Snakebyte1 in forum ComputerReplies: 0Last Post: 21st Mar 2018, 10:20
