  1. Hi,
    I recently got a SVCD where there is one MPG file in the MPEG2 folder, and yet when I view the movie with PowerDVD, I can press the Next button and skip about ten minutes of the movie. (Normally, pressing the Next button will end the movie).
    How do I make a SVCD in Nero where I can take one MPG file and make it so that when a person presses Next it will skip about ten minutes of the movie? From my newbie understanding of SVCDs, this can only be done if I break the one large MPG file up into several MPG files....
    I've read many of the HOW-TO in search of this info, and I thought I found the answer in the use of SCANDATA.DAT, but I couldn't find the answer that worked.
  2. Ulead DVD Movie Factory should to the trick.
    http://www.vcdhelp.com/dvdmoviefactory.htm
  3. VCDeasy can do and free
  4. Thanks for the responses, but I'm looking for a solution where i can just drop a file onto the SVCD that will put the chapters in without my having to open a new app and inserting them for every movie I want to burn.
    I've been reading some more FAQs, and it appears that the NEXT/PREVIOUS chapter information is stored in the ENTRIES.SVD file. When making a SVCD from an MPG, can I just copy the ENTRIES.SVD file from an existing SVCD (which skips every 10-15 minutes when NEXT/PREVIOUS is pressed) and drop it in a new SVCD and burn with Nero?
  5. Thanks for the responses, but I'm looking for a solution where i can just drop a file onto the SVCD that will put the chapters in without my having to open a new app and inserting them for every movie I want to burn.
    Aug 2001
    Västerås, Sweden
    well since you have to author anyway why not use TSCV or VCDeasy.
    there you can either set the second for each chapter or a chapter every X min. You can have vcdeasy burn it too.
    i dont know about the ENTRIES.SVD thingy but i know TSCV works a dream and is easy as easy can be.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
