Hello Everyone,
I have a few videos that have been made using the HEVC x265 format, and they don't seems to play properly using VLC on my old laptop.
Can anybody suggest a simple and fast way to convert these files to x264. I have tried Handbrake and it seems to take such a long time. Maybe I had it set up with the wrong settings.
Many thanks in advance.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Use a faster preset with the x264 Encoder Preset slider. Try veryfast. Quality will be a little lower. You can make up for that to some extent by using a lower Constant Quality setting (lower setting -> higher quality). If your GPU supports h.264 encoding you can try using that. It will show up in the Video Codec pulldown, if available. QSV, NVENC, etc.
Many thanks for the advice.
"Use a faster preset with the x264 Encoder Preset slider."
Is the x264 Encoder a separate download that integrates with Handbrake ? -
On windows, try mpc-hc with default evr-cp and see if it helps.
Also if your gpu is hitting 100% but your cpu is not overloaded try disabling hw-accelerated decoding.
Otherwise, reencoding with a more recent computer would probably be a better option. -
Yes, I think I need to use a more recent computer to do the reencoding.
Backup disintegrating DVDs up scaling and fixing plus convert to mkv (x265)
By Quantumleap in forum DVD RippingReplies: 13Last Post: 2nd Jan 2021, 13:38 -
Convert x265 4k to 60fps
By raumi19 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2017, 09:49 -
Converters won't convert MKV x265 encoded video
By NCC1966 in forum Video ConversionReplies: 3Last Post: 21st Dec 2016, 13:41 -
Convert video files to x265 in order to reduce file size?
By kingmustard123 in forum EditingReplies: 3Last Post: 2nd Oct 2016, 00:59 -
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 08:14
