  1. Hello everyone.
    I'm dealing with a video that has a lot of duplicate frames, thanks to that I need to use "DeleteFrame" and "InsertFrameMC" to correct it, because I already tried several automatic filters and none worked well.
    The question is, me and a friend do not understand the language of avs to create the function, in vs it works, but it does not have some necessary filters for post-processing the video.
    I'm trying to create a function that when inserting a certain frame, it will be deleted and interpolate the next one, without the need to repeat the filter over and over again.
    For example:
    FFVideoSource(\\video.mkv)
    DeleteFrame(100)
    InsertFrameMC(101)
    DeleteFrame(123)
    InsertFrameMC(124)
    DeleteFrame(132)
    InsertFrameMC(133)
    DeleteFrame(147)
    InsertFrameMC(148)
    The function would work as:
    FunctionAnyName(100, 123, 132, 147)
    In this example, frames 100, 123, 132 and 147 would be deleted and those listed above would be added with "InsertFrameMC".
    I appreciate the help.
    Sorry for the explanation if it is confused.
  2. I think what you want has already been done. The function FillDrops takes duplicate frames and replaces them with frames interpolated from the frames on either side.
    function filldrops (clip c)
    super=MSuper(c,pel=2)
    vfe=manalyse(super,truemotion=true,isb=false,delta =1)
    vbe=manalyse(super,truemotion=true,isb=true,delta= 1)
    filldrops = mflowinter(c,super,vbe,vfe,time=50)
    fixed = ConditionalFilter(c, filldrops, c, "YDifferenceFromPrevious()", "lessthan", "0.5")
    return fixed
    It only needs MVTools2.
  3. Originally Posted by manono View Post
    Man, it worked really well in the video I'm working on here, I can't believe it, I usually did it manually.
    I need to test on the other videos that I have this problem, it is usually NTSC> PAL conversion that causes this problem that I am seeing from the video making several jumps.
    I tried Dedup, Dup and several others and nothing, this one did very well, I hope it works on the ones I left out.
    Thank you very much.
  4. To do it manually (ie, in cases where filldrops() doesn't work -- like multiple duplicates in a row) use ReplaceFramesMC(), not DeleteFrame() and InsertFrameMC().
  5. Originally Posted by manono View Post
    I remembered the problem I had with "filldrops" in the past. This filter blurs some scenes, especially non-panoramic scenes. This filter worked well in the panoramic scenes that I have, I am thinking of using it only in some sequences of frames with a map or trim() (I don't know if it will work, I need to test it), something like:
    FilterMap="[481 2049] [8007 9221]" #panoramic scenes
    FilterLine=Filldrops()
    ReplaceFramesSimple(FilterLine, mappings=FilterMap)
    For some reason I had forgotten about ReplaceFramesMC(), I use InsertFrameMC() more often, but this filter doesn't do it in line either, but it is a better alternative than the method I mentioned above.
    Thank for help, guys.
