  1. Hi guys.
    Given a Dolby TrueHD audio track of a BD, how can I check if is in Atmos or not (the same for DTS:X)?
  2. Do you just have the audio track as a file on your PC? Or are you trying to find if the disc has Dolby Atmos? If just a file, you can check using MediaInfo GUI and it will tell you. Otherwise I would look up the disc on Blu-ray Forum and it will have the disc catalogued with what audio tracks it has.
  3. Originally Posted by stonesfan187 View Post
    I have both.
    What's the Blu-Ray Forum?
  4. Member Cornucopia's Avatar
    Just look at the box. If it has Atmos, it would be labeled as such.
  5. Originally Posted by Cornucopia View Post
    mean: not recognizing by listening, but technically. Any software? Any file to search for?
  6. Member Cornucopia's Avatar
    Has already been mentioned: mediainfo.
    Dolby allows for Atmos to be incorporated as an enhanced substream of either a TrueHD or an (E)AC3 (Dolby Digital/DD+) main audio stream, all encapsulated (muxed?) as 1 track.
