Hi.
The HardInfo program (https://www.linuxlinks.com/HardInfo/) include 6 different CPU/FPU benchmarks.
from the link above:
So - what I wonder - what kind of benchmark is most important / what should I look for - when the goal is performance for encoding x265 videos.Benchmark and compare your system:
CPU Blowfish.
CPU CryptoHash.
CPU Fibonacci.
CPU N-Queens.
FPU FFT.
FPU Raytracing.
Encoding uses both integer and floating point units. You won't get answer based on those benchmark. Btw. That x265 fhd benchmark will run fine under WINE. If you are real Linux user then this shouldn't be a problem.
The only benchmark that is relevant to x265 encoding is x265 encoding. BTW, since you like Handbrake, then you will like this:
https://handbrake.fr/docs/en/1.3.0/technical/performance.html
high core count cpu for x265 encoding good idea?
By sonyzz in forum ComputerReplies: 18Last Post: 6th Mar 2021, 16:57 -
Handbrake x265 encoding cpu doubt
By Sephiroth in forum Video ConversionReplies: 3Last Post: 17th May 2019, 07:29 -
Best CPU for encode Anime x265 10bit SraxRip
By nattapol in forum Video ConversionReplies: 8Last Post: 10th Jun 2018, 04:37 -
Best CPU for Anime encode x265 10bit SraxRip***[AVX2 vs AVX512]***
By nattapol in forum Video ConversionReplies: 2Last Post: 31st Mar 2018, 10:19 -
cpu working at 40% when encoding x265 on Megui
By zanzar in forum Newbie / General discussionsReplies: 9Last Post: 18th Dec 2016, 12:43
