I assume you have a user manual for the camera but just in case......
https://usermanual.wiki/JVC/GRD70E.1144567136/view
There is not much info there about PC transfer. It is not clear if you also have to use the switch settings on Page 34 - Video Dubbing.
Page 40 is the relevant one and the following caught my eye....
The system may not work properly depending on the PC
or capture board you are using.
Results 31 to 34 of 34
I looked at the user manual for your JVC camcorder and the instructions for playing or recording video via the 1394 connector begins on page 34. It appears that the unit switches between "video in" and "video out" simply based on whether you press the play or record buttons on the camcorder. This makes sense, but it also means that because there is no menu setting, you might not be able to get the camera into either the play or record state via the 1394 (i.e., you can't change anything from the computer). Thus, you will need to press the play button on the camera and then click on the "capture" button in Scenalyzer (or other app).
Thanks DB83 and johnmeyer.
Have tried your suggestions and get the same results.
Looks like im heading down the path of paying someone to do the transfers for me☹ -
It seems that the GR-D60 can send video over USB. Have you tried it?
The instructions on page 40 say:
Using USB cable. It is possible to do the following things:- Transfer still images stored on a memory card to a PC.
- Transfer still/moving images recorded on a tape to a PC.
- Capture still/moving images in real-time.
- Use this camcorder as a WebCam.
Converting Mini DV and/or Hi8 tape based videos to digital...
By jpilk99 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jan 2020, 20:59 -
Weird glitch on mini-DV tape prevents audio from importing
By Seghboth001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 24th Jul 2019, 18:39 -
digital video file to mini dv tape
By devdev in forum Video ConversionReplies: 10Last Post: 1st Jun 2019, 18:00 -
What is more important regarding quality of mini DV tape video capture?
By nwgal65 in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2016, 23:23 -
Audio out of sync when capturing AVI from Mini VHS Tape
By AvocadoTech in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2016, 21:29
