[Attachment 56907 - Click to enlarge]
Hello, complete newbie here, hopefully this is under the right topic. I'm editing a video in Windows Movie Maker (don't laugh) and for some strange reason the video I'm importing (720x480 4:3 MKV file) gets squashed down to a much tighter and uglier aspect ratio. When I play that video in VLC it appears as it should, in its original 4:3 aspect ratio, but when I play it in Windows 10 video player (Films & TV) or import it into WMM, it appears squashed even though I didn't change anything. Any idea why this is happening? Is there anything I can do to stop it? I've used other 4:3 MKV files in this Movie Maker project and they appear fine. I also know it's not a issue with my render settings as I can see it's messed up in the preview before I even render. I've attached before/after images (at least I think I have). Please enlighten me!!
Likely your file has a container DAR setting which some players/editors do not take into account (look for Display Aspect Ratio value with Mediainfo).
Resize the video to the correct resolution in your video editor if required. -
I ended up using Handbrake to convert the file to m4v, which did the trick for Movie Maker! Before that I'd tried updating the codecs with K-Lite but it only fixed the aspect ratio for Films & TV.
Videos from Dailymotion with incorrect aspect ratio?
By amgray19 in forum Video Streaming DownloadingReplies: 5Last Post: 18th Feb 2020, 01:05 -
Stretching video (changing aspect ratio)
By ddewaele in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2019, 11:17 -
Incorrect aspect ratio after authoring in FMPGEnc Authoring Works 6
By ibzomie in forum Authoring (DVD)Replies: 2Last Post: 19th Dec 2018, 09:14 -
Some Videos the original aspect Ratio is incorrect and will not convert.
By Kurt a Wells in forum Video ConversionReplies: 19Last Post: 23rd Jun 2017, 20:04 -
Converting 1:85 aspect ratio to 2:39 aspect ratio using Virtual Dub
By maxgremlin in forum EditingReplies: 1Last Post: 8th Jun 2017, 22:06
