Guys please I have found a bunch of old DVDs, mostly documentaries, which I am extracting with make mkv and than converting with ffmpeg and uploading to youtube.
This is the media info file:
Format/String : Matroska
Format_Version : Version 2
FileSize/String : 2.14 GiB
Duration/String : 49 min 29 s
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 6 197 kb/s
Encoded_Date : UTC 2021-01-10 15:17:58
Encoded_Application/String : MakeMKV v1.15.3 win(x64-release)
Encoded_Library/String : libmakemkv v1.15.3 (1.3.10/1.5.2) win(x64-release)
Video
ID/String : 1
OriginalSourceMedium_ID/String : 224 (0xE0)
Format/String : MPEG Video
Format_Profile : Main@Main
Format_Settings : CustomMatrix / BVOP
Format_Settings_BVOP/String : Yes
Format_Settings_Matrix/String : Custom
Format_Settings_GOP : Variable
Format_Settings_PictureStructure : Frame
CodecID : V_MPEG2
CodecID/Info : MPEG 1 or 2 Video
BitRate/String : 6 000 kb/s
BitRate_Maximum/String : 8 500 kb/s
Width/String : 720 pixels
Height/String : 576 pixels
DisplayAspectRatio/String : 4:3
FrameRate_Mode/String : Constant
FrameRate/String : 25.000 FPS
Standard : PAL
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Interlaced
And I am using this command:
I am upscaling to 2048x1536 'cause youtube very destroys quality if I upload pure mkv file from make mkv. Picture is 4:3 aspect ratio so 1080p resolution for this ratio is 2048x1536, 16:9 ratio is 1920x1080, 16:10 ratio is 1920:1200 and so on.Code:ffmpeg -i 1.mkv -deinterlace -filter:v yadif -vf scale=2048x1536:flags=lanczos -c:v libx264 -preset medium -crf 19 -acodec copy compress1.mkv
Edit: uploaded original and converted file, looks like some problem with deinterlacing.
ffmpeg command for disable vtt
By Alberto78 in forum Video ConversionReplies: 0Last Post: 22nd Apr 2020, 04:12 -
Need a command line for ffmpeg
By NTradd in forum Video ConversionReplies: 11Last Post: 14th Oct 2019, 11:25 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 12:42 -
ffmpeg nvenc command
By hanaluluelle in forum Video ConversionReplies: 8Last Post: 27th Jul 2017, 02:42 -
ffmpeg command line syntax
By sambat in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2016, 20:01
