Results 1 to 14 of 14
  1. My dashcam records to .AVI containers. They will not upload Facebook now. How do I change to .MP4? Tried two converters and they are all blocky.
    here is the media info
    General
    Complete name : C:\Users\dashcam\video.AVI
    Format : AVI
    File size : 58.5 MiB
    Duration : 26 s 100 ms
    Overall bit rate : 18.8 Mb/s
    Video
    Format : JPEG
    Codec ID : MJPG
    Bit rate : 18.2 Mb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.660
    Stream size : 56.8 MiB (97%)
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : 1
    Bit rate mode : Constant
    Bit rate : 512 kb/s
    Channel(s) : 1 channel
    Sampling rate : 32.0 kHz
    Bit depth : 16 bits
    Stream size : 1.59 MiB (3%)
    Alignment : Aligned on interleaves
    Interleave, duration : 967 ms (29.00 video frames)
  2. Try my clever FFmpeg-GUI.
    Convert the video with this settings:
    [Attachment 56885 - Click to enlarge]
    and the audio with this settings:
    [Attachment 56886 - Click to enlarge]
    Then mux the 2 resulting files to your final mp4.
  3. Works, thanks
    Edit it is .mkv won't open in Sony Vegas. I also need it be be edited in Vegas
    ok Vidcoder makes an mp4 that opens in Vegas
  4. Originally Posted by David Banner View Post
    Works, thanks
    You have muxed to mkv instead mp4.
  5. Originally Posted by ProWo View Post
    Works, thanks
    OK i see. I didn't mux just extracted video as did not need the sound. i will look at it tomorrow thanks
  6. I do not see where to choose mux as mp4? There is no dropdown for container like here https://www.videohelp.com/software/clever-FFmpeg-GUI
  7. Originally Posted by David Banner View Post
    Load first your video file, then your audio file, then set the desired output, then set the container. Click on multiplex, done.
  8. Originally Posted by ProWo View Post
    There is no box to set the output showing to me
  9. [QUOTE=David Banner;2608293]
    Target file
  10. There is no box showing to choose the container for the out put.
  11. Originally Posted by David Banner View Post
    [Attachment 56915 - Click to enlarge]
    Do you see Container?
    You can't multiplexing anything without setting an output file.
  12. No. Container not showing. I do set output folder
  13. Originally Posted by David Banner View Post
    Output folder and output file are two different things.
    Restart clever Ffmpeg-GUI, load your file, Main, Multiplexing.
    Set your Video track file, then set your Audio track file, then your Subtitle track file, if any.
    Then click on Target file, confirm the selected file name or choose another one, click ok in the Browser Window and you'll see the picture i send above.
    Select mp4 as container, click on Multiplex. DONE!
  14. Originally Posted by ProWo View Post
    Got it this time. Thanks
