which way of convertin rm to mpg has the best quality. im new here by the way, ooo yeah
[insert signature here]
Converting rm to vcd is not easy and the only proven way i know is to:
1. Use Hypercam to capture the real movie - video only
2. Use a registered version of TOTAL RECORDER to capture sound only
3. Use virtuadub or tmpgenc to encode to vcd.mpg
You will need to experiment with the initial sound file to get the sound into sync but it can be done.
An alternative to above is TINRA altho my attempts to convert have not been successful.
mikeboo
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
[FFMPEG -> VCD-MPG] How to push CBR?
By Gew in forum Newbie / General discussionsReplies: 4Last Post: 13th Apr 2009, 09:05 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 11:34
