Hi. Sorry, 9.08, nor 9.8. I use an old ATI Wonder Pro on an XP desktop to make transcripts from the software and video card for my website. Recently the desktop died and I took it to be repaired. They cleaned out the dust and now it works. However, I'm getting an error message when I try to run the TV tuner. It says:
"Unable to start TV
Check the Windows Device Manager to ensure that the correct video driver has been installed and is working properly before attempting to restart TV
PC Check may help diagnose this problem. Start PC Check utility after pressing OK (check box there and OK button)."
The PC check didn't work. Is ATI MMC 9.8 the driver I need? I don't see it listed in the device manager. There are about 5 different things listed there and none of them sounds like ATI.
I'm not a newbie, but I'm not an expert, either. I can't find the 9.8 driver if that's what I need. Will 9.15 even work on XP or my old hardware?
I only use the part of the software that grabs the closed-captioning from the TV shows and saves it as an HTML file.
Not sure to do so please help!
I uninstalled the software, but now I can't find the original software to reinstall. So stupid of me, I know.
This is the one I have: https://smile.amazon.com/ATI-Technologies-Wonder-PCI-NTSC-100-703138/dp/B0000C0COH/
Thanks!
Results 1 to 30 of 37
Methinks you are seeking 9.08 not 9.8 since 9.13 was the last version.
No idea if that would work for you. -
I tried to install 9.13 and it said it was installing, but then nothing happened.
There is a download link for ATI MMC 9.08 in this post: http://www.digitalfaq.com/forum/video-capture/392-ati-wonder-hacks-6.html#post29688
However, you must join DigitalFAQ to download the file.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thank you! Is this the multimedia program file or just the driver? It said it was installing and then nothing happened. There is nothing else installed that I can see....
Thanks, I did post there as well, but so far no one has been helpful...
That is not true. In this thread lordsmurf is giving you very clear and very specific troubleshooting instructions.
Just because you are choosing not to follow sound advice does not mean others are not being helpful. -
If I don't agree with said advice, then it's not helpful. I'm not some total newbie. I've been using computers since the 80's. He suggests I install a program that has nothing to do with what I need. I don't like installing unnecessary programs, do you? Anyway, he finally was helpful today so I'll be able to try to reinstall the program.
Thanks, but I don't think mine is listed there. My fault, not yours. I typed "all-in-wonder" when I meant to type "wonder pro". It's the ATI TV Wonder Pro 100-703138.
Thank you! I can't get the ATI software to install. I sent an email to the company that repaired my desktop to see if they can figure it out... I'm done trying on my own for now.
You can try 2 steps yourself to repair your XP system:
Step 1: Start, Run: Write here:
sfc /scannow
and run it.
After that reboot.
If the problem still exists, you can do a repair installation:
Step 2:
See here:
https://www.wikihow.com/Do-a-Windows-XP-%22Repair-Install%22 -
I will do the first part, but it's OEM windows software, and I don't have the windows setup or recovery disks.... I bought the computer about 4 or 5 years ago.
OK it won't let me run sfc /scannow without a Windows XP disk. It says "files that are required for Windows to run properly must be copied to the DLL Cache. Insert your Windows XP Professional CD-ROM now." Do I need to buy a copy of Windows XP, or just a recovery disk? Ebay has it for $10. https://www.ebay.com/i/324108673654 or I can get something called an emergency boot Disk from Amazon: https://smile.amazon.com/s?k=windows+xp+disk&ref=nb_sb_noss_1
Based on what?
(1) You're suggesting installing stuff without verifying the card is seen by the OS. ATI MMC is just a capture program for (some) ATI cards, not a driver, not a magic fix-all for a missing ATI card.
(2) Again, you do not "install" VirtualDub, but unzip and launch.
(3) In VirtualDub capture mode, you can see if the ATI card is even installed on the system. If so, it's a MMC problem. If not, the entire card is fubar.
What you're not seeing here is how ATI cards must usually be uninstalled with the uninstall utility. Then fully reinstalled. But to know if that's necessary, you need to see the status of the card.
You need to understand that I know far, far more than you do about ATI cards. (BTW, at one time, ATI referred to me for certain issues. Let that sink in.)
Ebay has it for $10Last edited by lordsmurf; 21st Jan 2021 at 23:27.
I didn't say I was a computer expert; I just said I wasn't a newbie. I've never taken a computer course. I don't know the inside workings of the computer (not much, anyway). I know Windows very well and many other programs. I've had many computers and had them fixed before, or fixed them myself when it's a software problem. I never claimed to be an expert.
The local computer repair place has helped me before. They were the ones who installed this card and software for me when I bought it 4-5 years ago. Previously, I had used the ATI TV Wonder USB, which is an external device that attached between the computer and the TV. There was no special card installation needed. It only worked with Windows 2000 or below, though, and my Windows 2000 laptop died, so I had to get a newer pc (with XP) and install the TV Wonder card instead.
We live in a very small town, so there aren't a lot of repair options.
I never claimed they were the ones that messed it up. You sure like to read what you want into what I'm saying. They fixed the first problem, which was that the computer was trying to boot up over and over again (and never succeeding). They cleaned it out because it had a lot of dust. After that, Windows seemed to work. The ATI program did not. They didn't do anything else besides clean out the dust (I asked). Now, it's possible the video card got loose during transport. Other than that, they didn't do anything AFAIK.
The ATI MMC is the program I need to make the card work. It's what I use for my site. I uninstalled it, but I don't have the original disk, so I needed the software in order to get it to work again. Then if it had installed but not worked, I would have installed the driver. Installation did not work, however. Yes, I'm going to try the things I know about first. Which is my right. And yes, I wanted to install the driver because the error message I was getting at first (before I uninstalled the ATI program) said "The TV player failed to initialize the video. Check the Windows Device Manager to ensure that the correct video driver has been installed and is working properly before attempting to restart TV." So the error message was saying, check the driver! Sometimes drivers get corrupted as I'm sure you know.
Thank you for explaining why I should install VirtualDub. No one else had done that. When I went to the link you had there, it talks about what it does, but it didn't seem to be what I needed when I first looked (I don't need anything to make the video look better). I do need someone to explain unfamiliar programs or utilities to me before I install them.
Please explain, though, why wouldn't the video card show up in Device Manager? I thought that showed all of the installed hardware.
You took "I sent an email to the company" out of context. The full sentence was "I sent an email to the company that repaired the computer." Of course I know that ATI/AMD wouldn't be helpful. I'm not the expert you are, but I have been using these ATI video Wonder things for about 20 years. in the past, I was able to get help from ATI, but that was long ago. And you're wrong about when AMD acquired ATI, too. It was 2006. I started using the ATI TV Wonder USB about 1999 and they did help me a few times with questions before they became AMD.
You can't possibly know if every single XP copy sold on ebay is fake or not. Even if it is; if it's a copy and works, then it was worth the $10 plus shipping. If not, I'm not out much.
I'm sorry you think my attitude sucks. I wasn't trying to be ungracious. I was just stating the facts as I saw them. I wasn't saying that no one was TRYING to help me, just that it wasn't helpful (as I saw it). -
Quick questions:
I did this and when I went to capture mode the screen is greyed out. Is there something I need to do to get it to look at the ATI card? I'm confused.
Isn't it possible the card just came loose?
I don't see anything except the regular intel card listed under display adapter.
I'm running system restore so I can get the software back to where it was and see if that might fix it. If not, then I guess the card is loose or not working.
Thanks again for your help....sorry again if I offended. -
System Restore brought the ATI program back, but now it gives me this error:
Language Resource file was not found:
C:\Program Files\ATI Multimedia\tv\TVDS???.RSC -
That may not be accurate. Which exact TV Wonder USB is/was it?
I never claimed they were the ones that messed it up.Whatever, moving on, blame doesn't matter...
I was recently building a system, and afterwards XP install hit a reboot loop. But it was BIOS settings and SATA/AHCI drivers, computer behaved when that was sorted. The CMOS battery was drained, and the XP install needed slipstreaming. That said, this has happened to me before, on an existing system -- more than once, over the years, actually -- and driver corruption, or hard driver failure, usually both together, was the cause.
But there are many issues that can cause it.
But what won't fix it? Canned air.
I like MMC. I need it too! Not for CC, but the excellent MPEG encoding for AIW.
Which is my right.
See the statement "and is working properly"? That's what the VirtualDub test is for. It will confirm if the card is working properly, outside of ATI software. So, proper scientific method.
Unfortunately, I doubt that'll end up much better. They don't seem competent.
Device menu > ATI card
But if it's not even showing in Device Manager anymore, it won't be anywhere now, not even VirtualDub.
Be sure to have backups of your data.
If the card is seated, yet the OS doesn't detect it, you likely have OS problems.
Thanks again for your help....sorry again if I offended.Want my help? Ask here! (not via PM!)
This is the TV Wonder USB that I used to use.
https://www.ebay.com/itm/ATI-TV-Wonder-USB-Tuner/333704792263
Here is what happened. I was running the transcript for a TV show. It was working. All of a sudden, the computer turned off. I went, WTF? and then it started to reboot. But then it turned off again. It was in some kind of loop. I had to unplug it. The repair guys said it was clogged with dust. Once they unclogged it, it was able to boot up. They couldn't test out the ATI function without connecting it to a TV or VCR; they didn't bother, anyway, because the main problem, we thought, was Windows not booting up correctly.
I don't have anything else on the computer. I only use it for this ONE thing. It only has Windows, the ATI program and the documents and photos I've generated from the ATI.
Did you see my other replies? The ATI card is not showing up in Device manager. When I use VirtualHub (I don't know if I'm using it right) there's a grey screen. Am I supposed to do something to tell it to look for the card?
I did a system restore, which brought back the ATI program. Now I'm getting an error message.
It does appear that the video card is not working or that Windows isn't seeing it.
Thank you! -
Thank you! It keeps timing out on me, though. I found another one, though. I've never worked with an ISO file. Once I transfer it to my other computer, will it see it as a Windows disk, or is there something I have to do to the file? Thanks
Oh, that won't work, then. I don't have a CD burner any more. I don't even have a DVD or CD drive on my current computer. That old one has the CD/DVD drive but no burner.
mount the iso to a virtual drive like Virtual CloneDrive (win10 has one built in) or open it with 7zip and extract the contents to a folder
990919 - Need driver for a DVR card
By hamidi2 in forum Newbie / General discussionsReplies: 10Last Post: 10th Dec 2020, 13:45 -
how do you make a software portable that has a driver
By elm in forum ComputerReplies: 5Last Post: 26th Nov 2018, 05:26 -
ATi TV Wonder Pro Pci window 7 x64 driver
By Milardo in forum Capturing and VCRReplies: 10Last Post: 12th Feb 2018, 18:04 -
FFInput driver 0.8.1 for Virtualdub help
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 25th Feb 2017, 03:20 -
EasyCap driver
By ronfarnham in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2016, 21:04
