I have a high quality audio interface for music recording - since this is essentially an analog to digital converter I would think I could use it to convert analog video from an old camcorder. Am I mistaken, and if not can anybody recommend a software that will do the task? (I am only concerned with the video, not the audio). Thank you!
It won't work with video since it's built for audio sources,check on the connections to see if any say "video out",if not no go.
Video frequencies are three orders of magnitude higher than audio. Audio capture hardware will not work for video.
Customizing PotPlayer interface for Audio Playback
By potuser in forum Newbie / General discussionsReplies: 6Last Post: 3rd Mar 2020, 09:05 -
Display Hotkeys in Interface
By Morbott in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2019, 09:09 -
SDI/HDMI to USB3 interface that also ingests 8/16 audio channels
By regstuff in forum Capturing and VCRReplies: 4Last Post: 16th Mar 2019, 03:18 -
PAL SD Video capture trough audio interface?
By Axelwaad in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2019, 13:02 -
The new Potplayer User Interface
By falconeye007 in forum Software PlayingReplies: 5Last Post: 22nd Feb 2017, 09:00
