I'm sure this is covered somewhere but i spent a while hunting it and couldn't come up with an answer.
What i would like to do is the following.
Local recording from OBS as an MKV of a 5 hour stream.
Remove the 5 minute countdown, a few breaks here and there (2-5 minutes), the 2 minute outro, replace them with a custom intro/outro, end up with a single file preferably with one "pass through the program" If i cant add my own intro/outro on the same pass that is VERY OK. ( i've written a batch file with ffpmeg to handle this for option 2(down below))
Right now the only thing i can seem to do is split the 5 hour recording into the parts i WANT to keep, each part being a separate file when the processing is done. This works for some other use cases when i want to set it up in separate episodes ( Option 2 below )
The very end goal is to end up with knowing the options of how to do:
OPTION 1
"cutting out unwanted parts from one recording leaving one file (if possible with custom intro outro)" 1 processing through mkvtoolnix
OPTION 2 ( i know this one )
"splitting out chunks into episodes and then running them though an ffmpeg batch file to add custom intro/outro" 1 processing through mkvtoolnix
Sorry if that seems hard to follow
TLDR: remove multiple parts of mkv, end up with one mkv w/o having to run mkvtoolnix a 2nd time.
Thanks,
Grid
Results 1 to 1 of 1
Converting multiple video files to MKV using MKVToolnix
By pcmacbob in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2022, 13:24 -
Joining MKV with subs in multiple languages with MKVToolnix
By Tedbax in forum EditingReplies: 4Last Post: 3rd Mar 2019, 03:53 -
Issing re-joining mkv files split using mkvtoolnix
By Odaik in forum Video ConversionReplies: 47Last Post: 31st Mar 2017, 15:25 -
Replacing thumbnail on .mkv file using mkvtoolnix or mkvmerge
By PeterProg in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2017, 23:56 -
Need help muxing WEBM/VP9 to MKV (MKVToolNix GUI)
By bitrape in forum Video ConversionReplies: 8Last Post: 11th Aug 2016, 23:38
