Hi, when I covert a file into MP4 using Any Video Converter, it always fails. This does not happen when I try to convert to AVI or WMV formats. Does anyone know the cause and fix to the problem? I thank you much for your help.![]()
Closed Thread
Results 1 to 10 of 10
Well, I already bought Any Video Converter so I want to get it to work. Any suggestions of the fix?
Which format are you trying to convert to Mp4 ? - please provide MediaInfo (or MedaiInfoLite) details of the source file.
Maybe the audio codec of the file you are attempting to convert does not suit the Mp4 format container.....
PS this is nothing you cant achieve with the free and gorgeous ffmpeg, my friend.
Hi Codehound, below are details of the log file. Any idea of the problem?
[2021-01-18 19:25:16,933] INFO main : ---------------------------------------------------------------------------
[2021-01-18 19:25:16,933] INFO main : Logger initialized.
[2021-01-18 19:25:16,935] INFO main : Windows Version Information:
[2021-01-18 19:25:16,935] INFO main : Major Version = 10
[2021-01-18 19:25:16,935] INFO main : Minor Version = 0
[2021-01-18 19:25:16,935] INFO main : Build Number = 19041
[2021-01-18 19:25:16,935] INFO main : Platform Id = 2
[2021-01-18 19:25:16,935] INFO main : Version =
[2021-01-18 19:25:16,935] INFO main : Windows 10
[2021-01-18 19:25:16,978] INFO EnumSystemVideoCards : Enumerator system video cards...
[2021-01-18 19:25:17,767] INFO EnumSystemVideoCards : Video controller: [1, Intel(R) HD Graphics 520]
[2021-01-18 19:25:17,767] INFO EnumSystemVideoCards : Video controller: [2, NVIDIA GeForce 940M]
[2021-01-18 19:25:17,767] INFO IsNvencAvailable : Loading nvenc functions...
[2021-01-18 19:25:17,768] INFO IsNvencAvailable : Nvenc version 10.0
[2021-01-18 19:25:18,710] INFO IsNvencAvailable : Nvnec available, devices: 1
[2021-01-18 19:25:18,710] INFO check_component_available : Loading library amfrt32.dll...
[2021-01-18 19:25:18,712] INFO check_component_available : VCE: Load Library amfrt32.dll Failed
[2021-01-18 19:25:18,713] INFO check_component_available : Result: 1
[2021-01-18 19:25:18,713] INFO IsQsvAvailable : Checking Intel Qsv...
[2021-01-18 19:25:19,297] INFO IsQsvAvailable : Intel Qsv H264 encoder : 1.
[2021-01-18 19:25:19,683] INFO IsQsvAvailable : Intel Qsv H264 encoder (constant quality) : 1.
[2021-01-18 19:25:20,208] INFO IsQsvAvailable : Intel Qsv H265 encoder : 1.
[2021-01-18 19:25:20,734] INFO IsQsvAvailable : Intel Qsv H265 encoder (constant quality) : 1.
[2021-01-18 19:25:20,855] INFO CVideoConverterDlg : Finding register name/code...
[2021-01-18 19:25:21,065] INFO CVideoConverterDlg : Register name: Vovan
[2021-01-18 19:25:21,067] INFO main : win_sparkle_init.
[2021-01-18 19:25:21,183] INFO main : SQLite version: 3.29.0
[2021-01-18 19:25:21,194] INFO CVideoConverterDlg : Version : Any Video Converter Ultimate 7.0.8
[2021-01-18 19:25:21,562] INFO CVideoConverterDlg : Internet connection available, checking module version...
[2021-01-18 19:25:21,562] INFO CreateAVCDownloader : Create downloader object, output folder: C:\Users\sanca\Videos\Any Video Converter Ultimate
[2021-01-18 19:25:24,120] INFO CDownloaderImpl::GetYoutubeDLVersion : Download engine version: 2021.01.08
[2021-01-18 19:25:24,120] INFO CheckModuleVersionThread : Checking module upgrade version...
[2021-01-18 19:25:24,120] INFO CheckModuleVersionThread : Downloading youtube-dl version file C:\Users\sanca\AppData\Roaming\Anvsoft\Any Video Converter Ultimate\yt_ver.ini...
[2021-01-18 19:25:24,120] INFO CCheckUpdateDlg::GetFile : Downloading file from url: http://update.any-video-converter.com/ver_youtube-dl.ini
[2021-01-18 19:26:08,579] INFO CMediaHandler::ImportMedia : Importing media C:\Users\sanca\Downloads\HC.The.Crusades.Crescent.and.The.Cross.1of2.The.Firs t.Crusade.1080p.BluRay.x264.AC3.MVGroup.org.mkv...
[2021-01-18 19:26:13,710] INFO CMediaHandler::ConvertMedia : Transcoding media...
[2021-01-18 19:26:13,712] INFO CFFmpegCmd::threadMain : "C:\Program Files (x86)\Any Video Converter\gnu\ffmpeg.exe" -noautorotate -i "C:\Users\sanca\Downloads\HC.The.Crusades.Crescent .and.The.Cross.1of2.The.First.Crusade.1080p.BluRay .x264.AC3.MVGroup.org.mkv" -map 0:0 -map 0:1 -y -vf "scale=1920:1080[1];[1]pad=1920:1080:0:0" -aspect 16:9 -ar 44100 -ac 2 -r 29.97 -c:a libfdk_aac -b:a 128k -profile:a aac_low -c:v hevc_nvenc -rc vbr_hq -cq 22 -qmin 22 -qmax 22 -threads 0 "C:\Users\sanca\Videos\Any Video Converter Ultimate\MP4\HC.The.Crusades.Crescent.and.The.Cros s.1of2.The.First.Crusade.1080p.BluRay.x264.AC3.MVG roup.org_x265.mp4"
[2021-01-18 19:26:14,527] INFO ffmpeg.error : [hevc_nvenc @ 09f08940] OpenEncodeSessionEx failed: unsupported device (2)
[2021-01-18 19:26:14,564] INFO ffmpeg.error : [hevc_nvenc @ 09f08940] No NVENC capable devices found
[2021-01-18 19:26:14,564] INFO ffmpeg.error : Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
[2021-01-18 19:26:14,566] INFO ffmpeg.error : [libfdk_aac @ 09f09a80] 2 frames left in the queue on closing
[2021-01-18 19:26:14,574] INFO CFFmpegCmd::GetExitCode : Command exited with 1.
[2021-01-18 19:27:45,201] INFO main : Logger uninitialized.
No Luck Muxing a MP4 with a MP3, all software fails, each plays in VLC
By TBoneit in forum Video ConversionReplies: 12Last Post: 24th May 2019, 07:20 -
Help with video conversion - Handbrake / AVC (Any Video Converter)
By higenbs1 in forum Video ConversionReplies: 9Last Post: 1st Mar 2018, 16:13 -
ffmpeg video conversion to mp4
By dabomb_gent in forum Video ConversionReplies: 4Last Post: 7th Dec 2016, 06:30 -
What do you use to convert AVI or MP4 to DVD ISO images when DeVeDe fails?
By rocksockdoc in forum Video ConversionReplies: 9Last Post: 25th Aug 2016, 21:00 -
Any Video Converter not saving as MP4's anymore (Help!)
By ThrowawayQuestion in forum Video ConversionReplies: 2Last Post: 12th May 2016, 13:54
