    Aug 2014
    Switzerland
    Hi there,
    I'm trying to capture/download videos with mozilla add-ons but no ones is successful since I have no sound. Some add-ons give me separately one sound file and another video file, and others give me only one video file without any sound track. I can download from youtube easily with ''Easy Youtube Downloader Express'' (what a complex name...), but with that add-on it's imposible to download videos on the following website (in the past I did it well but now it seems like impossible).
    https://www.arte.tv/fr/videos/098775-000-A/le-bateau-l-histoire-d-une-superproduction-sous-marine/
    Thanks for your help
    Dec 2020
    Germany
    Try youtube-dl out.
    It should work with the command:
    youtube-dl.exe -F https://www.arte.tv/fr/videos/098775-000-A/le-bateau-l-histoire-d-une-superproduction-sous-marine/
  3. ^^ Correct. BUT.........
    Note: You may need ffmpeg.exe for Windows in the same directory as youtube-dl and we need to combine the separate audio + video files available.
    A format request syntax provides the following (note case sensitive F):
    youtube-dl -F "https://www.arte.tv/fr/videos/098775-000-A/le-bateau-l-histoire-d-une-superproduction-sous-marine/"
    [Attachment 56841 - Click to enlarge]
    So to download the best FR version; simply use the syntax (note case sensitive f):
    youtube-dl -f HTTPS_SQ_1+HLS_XQ_1-2255 "https://www.arte.tv/fr/videos/098775-000-A/le-bateau-l-histoire-d-une-superproduction-sous-marine/"
    OR to download the best DE version (note case sensitive f)::
    youtube-dl -f HTTPS_SQ_2+HLS_XQ_2-2255 "https://www.arte.tv/fr/videos/098775-000-A/le-bateau-l-histoire-d-une-superproduction-sous-marine/"
    **No need for the .exe in the syntax.
    **Do not use
    youtube-dl "url"
    .........either (ever) as this is a hit and miss method for actually acquiring you the 'best' version.
    If you cant manage here's the 'best' FR version
    https://yadi.sk/i/iM7n3a09KxRAMg
    Dec 2020
    Germany
    Really? On my Windows it only works if I add .exe
  5. Yes really. On both the Windows executable and the unix based versions.
    Similarly for ffmpeg.
    See a thousand or so examples https://forum.videohelp.com/forums/48-Video-Streaming-Downloading
    Aug 2014
    Switzerland
    Seems to be so complex. Should I creat a command line for each videos of that website?
  7. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    see your PM here.
    Feb 2008
    Poland
    Download youtube-dl-gui.
