Results 1 to 14 of 14
    Jan 2021
    seattle
    I made many DVD picture slideshows with music back in the 2006 time frame. I have the DVD file copies on a hard drive, but can't seem to open or remember what old program I used to make them (Sonic, Pinnacle, Roxio, iMovie/photos. or ?) I am on a PC with win10 and I can only view the source directory with VLC. Below is what the DVD file structure looks like (No AUDIO_TS OR VIDEO_TS). Any help wound be much appreciated!
    [Attachment 56825 - Click to enlarge]
    canada
    Moved the thread to conversion,isn't latest video news and please don't post duplicated threads,one is enough.
  3. Turn off Explorer's "Hide extensions for known file types" option so you can see the actual file extensions. My guess is that "Megs Graduation" is a .VOB file and the folder called Sources contains the original source files (AVI?) that were used to make it. So that isn't a disc meant to be played in a DVD player, but an archive of the project. I don't recognize what software that may have been. Maybe if you show the content of the Sources folder (with extensions) it will be clearer to somebody.
    canada
    I looked up jacket_p and it's a directory that holds MPEG-2 encoded pictures of the cover art (usually) for the disc. It can be used by some players as background for splash screens, screen saver, etc... not that many support it, though.This is taken from a doom 9 forum post.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    really doubtful that dvd disc would have auto-played on any dvd machine. maybe it opened as a list of files. upload the "dvd file" off the disc and let's see what it contains. most likely a vob, or maybe an mpg2. it could have been made with the old windows program windows movie maker/dvd maker.
    Jan 2021
    seattle
    Thanks for you thoughts. Sorry about the double post...my bad. Here is what' in the directory. I do think you are correct that is was some slideshow program like movie maker....
    The .DVD file and one from the Jacket_P dir
    Jan 2021
    seattle
    Here are files from the Sources dir's
    Jan 2021
    seattle
    The .dvd file wouldn't send
    This is a pic files in the slideshow dir of Sources .... it wouldn't send either 100-0019_IMG-fade-110372.mpeg - Invalid File
    Jan 2021
    seattle
    Maybe its time to forget all these DVD's I made
  10. The files that wouldn't upload can be zipped up into an archive and the archive uploaded.
    J00___5L.MP2 has a menu:
    [Attachment 56835 - Click to enlarge]
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    something is missing. it would be many megabytes long not the ones posted that are under 1MB
    Apr 2003
    Sometimes MediaInfo's "writing application" section tells me what software was used to create video files.
  13. Videomp24x3NTSC720x480.mpg is an mpeg elementary stream but only contains a single black frame.
    General
    Complete name                            : Videomp24x3NTSC720x480.mpg
    Format                                   : MPEG Video
    Format version                           : Version 2
    File size                                : 5.25 KiB
    Duration                                 : 33 ms
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 304 kb/s
    FileExtension_Invalid                    : mpgv mpv mp1v m1v mp2v m2v
    Video
    Format                                   : MPEG Video
    Format profile                           : Main@Main
    Format settings                          : CustomMatrix
    Format settings, BVOP                    : No
    Format settings, Matrix                  : Custom
    Duration                                 : 33 ms
    Bit rate mode                            : Variable
    Maximum bit rate                         : 9 000 kb/s
    Width                                    : 720 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 29.970 (30000/1001) FPS
    Standard                                 : NTSC
    Scan order                               : Top Field First
    Time code of first frame                 : 00:00:00:00
    Color primaries                          : BT.601 NTSC
    Transfer characteristics                 : BT.601
    Matrix coefficients                      : BT.601
  14. Type into a Windows command line window:
    dir X:\*.* /s >C:\list.txt
    (where X ist the drive letter with your DVD in).
    Then post the list.txt file (you'll find it in the root directory from drive C) here.
