Have a blu ray feature that's encoded NTSC at 24 fps. Ripped it to MKV so I could encode in Handbrake and burn back to BD-R (because I burned-in a subtitle track). My question: What should my settings be under "Filter" if I want to keep the newly-encoded file at NTSC 24fps for playback on a stand-alone blu ray player? The original file is progressive, btw, not interlaced. Also aware of the bluray=compat command. Anything else I should be aware of? Under the "Video" tab, I clicked "same as source" for fps and used Constant Frame Rate. Just not sure if I should set for 3:2 pull-down and/or invert telecine.
Results 1 to 1 of 1
using MAKEMKV and HANDBRAKE to copy Blu-ray disc
By Fr@nkC@$tle in forum Newbie / General discussionsReplies: 2Last Post: 18th May 2020, 20:21 -
Website where I can find all correct specifications of Blu-ray releases?
By Ruude in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2019, 17:59 -
Handbrake settings for PAL to NTSC?
By kpic in forum Newbie / General discussionsReplies: 16Last Post: 5th Jun 2019, 14:19 -
Why does Handbrake show less duration of the blu-ray?
By batemanj in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2019, 23:30 -
How to convert Compact Disc Audio speed to a Blu-ray (24fps) Audio speed?
By Gwar in forum AudioReplies: 13Last Post: 12th Feb 2019, 06:21
