I used tmpgenc to convert the AVI to mpeg1. And then use nero (also tried easycd creator) to burn it to a VCD, but the vcd player can't play the VCD. Anybody having the same trouble? how can i fix it?
Results 1 to 10 of 10
Does your player play bothvcd and cd-r?
If your not sure look in the dvd players compatability list link is to the leftWe were all NEWBIES once and the only stupid question is the one that's not asked? -
What guide did you use?
also what codec is the file in?
Ok start explaining exactly what you did with this avi fle.We were all NEWBIES once and the only stupid question is the one that's not asked? -
OK, i use the 'Microsoft AVI' in Premiere to export the timeline to AVI file. And then use tmpgenc 2.54.36.134 (use TibrO VideoCD template) to encode the AVI to mpeg1. Use nero 5.5.7.8 to make the vcd.
First question
where did you get this file is it downloaded or did you do a dvd rip?
How come you didn't use the divx to vcd all in on guide?We were all NEWBIES once and the only stupid question is the one that's not asked? -
I captured the file from Dv (use dazzle DV.now AV).
Use divx is a better solution? tell me more please -
I don' t know anything about capturing and converting. You put your post in a newbie forum. I think you should put it in the capture forum and explain it with good detai so you can get a quick answer.I'm sure you will.
Sorry I couldn't help
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Hi,
If the VCD you have created is NON STANDARD, then it will not play on many stand-alone VCD player. My Pioneer doesn't.
Diffuser home made
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2009, 05:56 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 06:57 -
DVD with a home made video of a wedding can not get it work on dvd player
By kyrieanddave in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 12:03 -
Home made AVI to FLV
By Eibach in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:25 -
LG DN788 not read VCD?
By joselect in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Nov 2007, 14:04
