While I seem to burn an mp4 to disc successfully - I keep getting this in my DVD: RW drive? Am I doing something wrong? Thanks.
Results 1 to 10 of 10
does the burnt disc play ok ??
if yes, then it may be just a bug in the burning software. -
Hi - Thank you for getting back to me so quickly. Yes it plays ok. It shows both VOB's and the mp4 (the latter is under the title - 'Files Ready To Be Written to Disc'
That's just a windows message when you have burned a disc,just ignore it.
Don't delete anything from this thread,other people might have the same issue and find the answer here unless you meant video files.
I didn’t mean delete from the forum! I meant when I see the message. Thanks again
You can delete it but it goes away,it will happen and again the more your burn.
I assume that you have burned the small amount of data on a DVD? And does it work with it?
You can try to burn the same data - plus approx. 200 MB in addition (pictures, videos or something) again and in the same way with the same disc. Nero will then report that your disc already contains data, etc., confirm the message and, after burning, try whether the new data is (with) on the DVD.
If this is the case then everything is OK. Otherwise you have to inform us of a new status again.
Disc only has VOB files....need no rebuild
By Loplop in forum Authoring (DVD)Replies: 3Last Post: 10th Nov 2020, 08:48 -
Why does written DVD playback stuck on standalone player?
By Bencuri in forum Authoring (DVD)Replies: 29Last Post: 17th Oct 2019, 14:19 -
Tutorial on making a video with written lyrics of an audio/song?
By remtin in forum EditingReplies: 7Last Post: 24th Nov 2018, 01:24 -
Convert multiple files together to fit on 1 BR disc
By Toro in forum Authoring (Blu-ray)Replies: 0Last Post: 5th Mar 2018, 08:17 -
mp3 making and false information written in the document
By sommers in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2017, 09:47
