Hi,
I'm searching for the product that can receive signals from external DVD player / VHS Player. I have Intensity Pro 4K, which can take composite connection too (so to use VHS player too) to send it to my PC and makes PC as television. I have been using IP4K otherwise to capture input taking only. If composite sound output is simulataneously connected to audio amp, is it functioning like television or monitoring sound at the same time with video input?
Results 1 to 1 of 1
Manual for original Blackmagic Intensity pci-e card
By ereiamjh in forum Capturing and VCRReplies: 14Last Post: 25th Feb 2020, 09:16 -
Blackmagic intensity 4k - missing scenes!
By hdfills in forum Capturing and VCRReplies: 13Last Post: 6th Feb 2020, 14:42 -
Sony SVO-5800P -> Blackmagic Intensity Pro
By paulsoulsby in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2018, 11:07 -
Blackmagic Intensity Pro 4K suddenly starts introducing stutter
By bschneider in forum Capturing and VCRReplies: 31Last Post: 20th Feb 2018, 18:15 -
Blackmagic Intensity Pro - Reducing 1920x1080 Captures to Lower Resolution
By Involuntary in forum Capturing and VCRReplies: 2Last Post: 31st Aug 2016, 04:12
